F boxster versus Spec boxster
Some good looking SPB's.
f boxster are really great car
Good power/weight ratio
Can be competitive againts g, h , i class if your a good driver.
Good for DE as well. Yes the newer car will pass you on a straight line like if your were parked but the fun starts in the corners.
Perfect Angel
Thinking about building or buying a Boxster S for Stock class F. Would use for DE for 2017 and start club racing 2018.
Other than the donor car, is there any real difference in the build assuming a 2002-2004 Boxster S as a starting point? I've seen suspension kits for Spec Boxster from Tarret and Tune RS. I assume these would work for a F as well.
Any insight into the differences bewtween these two builds would be helpful.
Thanks in advance.
Thanks in advance.
And if I'm not mistaken there are some small suspension geometry differences between the Gen 1 Boxster and the 200-2004 car so be careful buy components.
That being said the F Boxster is a strong car for the class and the SPB is a hoot as well.
A: Anyone know which of these builds has greater versatility beyond PCA clubs?
Specifically:
1. Does the F-Class Box have a racing category in SCCA or NASA?
2. SPB-class cars have been placed in T3 with SCCA, but is there a NASA class for them?
B: If anyone has any actual info /or educated guesses on the comparison of costs per weekend between these two classes I'm all ears. Seems to me tires and suspension would be the obvi greater costs for the F class cars, just wondering what this might translate into dollars-wise?
C: Which is FUNNER? Anyone who's sampled both?
No concrete answer on A, but for B. I would say it's a wash on the suspension as once it's purchased the cost doesn't effect the race weekend. Other than that the set of Hoosiers will run a few hundred more per weekend (only need one new set). Personally I only run a new set of Toyos every other race but I may try a new set for each race this year.. Transaxle is a little stouter in the newer Boxster S so you may consider the SPB gearbox expendable after 5 races at a cost of about 200 per weekend or so..
3 Qs
Specifically:
Specifically:
