Dundon Finger Follower Wear/Cam Wear Fix Update, and Engine Health Monitoring Intro
Old 01-07-2017, 03:47 PM
Jamie@dundonmotorsports
Basic Sponsor
Jamie@dundonmotorsports's Avatar
Default Dundon Finger Follower Wear/Cam Wear Fix Update, and Engine Health Monitoring Intro
Hello all,
We've received the G.2 Heads and latest revision of cams for us to get final fitment of the finger follower and solid lash adjuster fix.
Looked at the G.2 Heads and there are oil squirters for the exhaust cam and none for the intake. We're going to review adding a spray bar to for the intake side as well to help ensure lubrication. With the lash under control it might be overkill, but it won't hurt...
The heads and cams are all on their way for final measurement. We have to make cams for this kit, so we're going to make a them a bit hotter than stock for a bit more power while you're saving your engine from potential damage. We're also looking at a hot rod head that would include Ti valves and a CNC port on the exhaust side (it's just as cast currently).
Here's some pics:
DLC coated camshafts
Valves
Exhuast port
Crankcase Pressure Monitoring System
We're also putting together a crank case pressure logging system with a small logging screen and piggy backing on other work we've been up to decoding the engine computer and car CAN streams to be able to log numerous parameters
Crank case pressure is a vacuum and should stable when the rings are sealing well. As the cam/finger followers wear, metal debris will circulate in the engine and rings and cylinder walls will be worn (as we've seen from pictures from other rennlist members). As the rings and cylinder walls wear the combustion gasses will leak past the rings and the crank case pressure will increase.
The nice thing is Porsche already has a crank case pressure sensor on the car and it can be read with the factory tester. What we're doing is getting the data without the tester and allowing you to log it over time.
The best way to do this is likely at every oil change monitor it for a tank of gas and compare to historical levels. We have all the components including a screen/logger on the way and we're in the final prototype for our CAN decoder. (can do lots of other really cool stuff with the CAN decoder like log brake pressures, ride height for aero development, engine parameters, anything a PIWIS can read we can get and log...)
Just wanted to start a thread to let you know we're working the issue on multiple fronts, both from a monitoring the health of the engine before you get a misfire code, in addition to being able to fix it permanently...
We're testing the monitoring this week, and building the CAN library. More after that!
Dundon Motorsports
Gig Harbor, WA
253-200-4454
jamie@dundonmotorsports.com
www.dundonmotorsports.com
Facebook.com/dundonmotorsports
Instagram @dundon_motorsports
Old 01-07-2017, 04:04 PM
bronson7
bronson7's Avatar
Great work Jamie, I'll be paying special attention to this thread as many others will also.
Old 01-07-2017, 05:36 PM
PhilT3 (PT3)
PhilT3 (PT3)'s Avatar
LOVE it! Will you also make these for RS?
Old 01-07-2017, 05:37 PM
Macca
Macca's Avatar
Great work Jamie. Im really looking forward to following this thread closely.
Just for clarity can you define "G.2" heads and supply a part number for those. I assume these are the very latest heads fitted to the G1/G6 etc swap out crate engines that are now being fitted to cars under warranty?
Old 01-07-2017, 07:38 PM
RajDatta
RajDatta's Avatar
Congrats on all these developments. Seems very promising. Subscribing.
Old 01-07-2017, 09:44 PM
Basic Sponsor
Absolutely, 991 GT3 and RS
Will grab the part numbers, but yes they are the latest, and the latest cams...
Saw you have a GT4 coming, getting all kinds of toys!!
Old 01-08-2017, 12:08 AM
CDinSing
CDinSing's Avatar
Jamie,
Great work! The crankcase pressure monitor is an excellent idea for acting prior to major failure. I love it! Also looking forward to the head and cam solution. I will be subscribed.
Good luck with the development and testing phase!
Old 01-08-2017, 02:12 AM
PhilT3 (PT3)
Let's start voiding warranties!!!! Yeah baby!!!!
Old 01-09-2017, 02:21 AM
Basic Sponsor
9A1 104 911 BX
Old 01-10-2017, 01:43 AM
Alan C.
Alan C.'s Avatar
Received 1,061 Likes on 547 Posts
Makes me regret selling the GT3.
Old 01-10-2017, 01:54 AM
Basic Sponsor
Could probably sell the GT4 and get into a used GT3 pretty cheap...
Old 01-10-2017, 03:11 PM
Alan C.
Alan C.'s Avatar
Thinking about it.
Old 01-10-2017, 04:30 PM
FredGT3
FredGT3's Avatar
Thanks Jamie, will you sell directly to the UK or look for a distributor?
Regards
Fred
Old 01-11-2017, 01:01 AM
PhilT3 (PT3)
Thinking about it.
Want to know my opinion............?
Old 01-11-2017, 02:18 AM
Alan C.
Alan C.'s Avatar
No idea.
Quick Reply: Dundon Finger Follower Wear/Cam Wear Fix Update, and Engine Health Monitoring Intro
