Drive Clean Test - Failed
Old 05-26-2014, 06:10 PM
CATA19
CATA19's Avatar
Default Drive Clean Test - Failed
Just had my drive clean test done as I need to get my plates renewed and it failed.
I have a 1999 Carrera. When I purchased it, I was told it had a Pfaff Tuning exhaust and GIAC software. I store the car for the winter and disconnect the battery. I have put about 850 km on it since taking it out of storage and reconnecting the battery.
The last drive clean was in April, 2011 and was the 2 speed idle tailpipe inspection. It passed.
This test was the OBD-II Inspection. The test results said that the Catalyst status was Not Ready, and it came up wit a Diagnostic Trouble Code of P1691. Everything else said the status was Ready or Not Applicable. It also was a "Yes" to the question "Is the MIL commanded on?".
Any help, explanations, etc.... would be greatly appreciated!
Old 05-26-2014, 06:27 PM
CamsPorsche
CamsPorsche's Avatar
Do you have only 1 not ready? If so, you are allowed to pass. More than 1 and you have to do a drive cycle. You might want to call a dealer or Google the right steps.
I just went through this with my ex-997 and wrote a DIY for it:
https://rennlist.com/forums/showthre...ferrerid=68774
Old 05-26-2014, 06:38 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Since you have the check engine light on, that's pretty much a fair right away. Do you know what the trouble code stands for? I'm on my phone and can't check it.
Old 05-26-2014, 06:48 PM
theiceman
Team Owner
theiceman's Avatar
Received 1,026 Likes on 730 Posts
Okay here we goo .. one more time
Your MIL was set as a fail .. that is why you failed .. They will not fail you for readiness check . I think with a 99 you are allowed two monitors to not set. But that can be difficult . On my Audi i can monitor them for readiness.
Was your MIL lght on ? if it wasnt it should have been .. does it come on when you turn on the ignition ? It should come on as a test. if it doesnt your MIL light has been disconnected. ' MIL commanded on" means that light should be on . if it isnt id suspect tampering ..
soooo what can you do
first get the MIL fixed...
then reset monitors and see how long before the MIL light comes on. If it comes on immediately you have no choice but to fix it as this is a fail.
if it stays off get an OBD2 reader with emisions staus .. leave it connected and drive around till it goes from yellow to green . You may even be able to get it to pass at yellow for a 99 but i am not sure how to tell how many monitors are set.
If you tell us what that code means we maybe able to help you more
http://www.aa1car.com/library/obd_monitor_not_ready.htm
some good reading that may apply to you.
Old 05-26-2014, 06:53 PM
CATA19
CATA19's Avatar
What is weird is that my engine light on my dash is not on. Not sure if bulb is blown, if the PO disconnected it for some reason, or if there are other issues.
Any suggestions on how to check to see if it is disconnected or how to change the bulb?
On the report they gave me, the description for code P1691 simply states "Manufacturer-specific diagnostic trouble code". Haven't had a chance to look it up yet (hoping to get some time later tonight).
Old 05-26-2014, 06:55 PM
theiceman
Team Owner
theiceman's Avatar
read my post
does it come onwth ignition if not PO disconnected it to sell it .. guarenteed
Old 05-26-2014, 07:00 PM
theiceman
Team Owner
theiceman's Avatar
Thats funy i just looked up that coe ...
it is a failure for " open MIL light circuit"
in other words the code is telling you your MIL lght circuit isnt working. if you fx that you just might be okay .. i guess you could start out by putting the bulb back in
Old 05-26-2014, 07:42 PM
Torontoworker
Torontoworker's Avatar
P1691 is a CEL lamp burnt out. System checks lamp on start up and gets a no connection response (open circuit) and records a P1691. Replace the lamp and go through your driving readiness procedures (the procedures are around here somewhere) again. Next time do not disconnect your battery over the winter - buy a battery maintainer for $70 bucks, (although that has noting to do with the bulb burning out). Might be time (while your in there mode) to change the other lamps as well do to age of car.
Old 05-26-2014, 08:22 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
The bulb could be missing. It takes a long time for a lit check engine bulb to burn out it is more likely someone pulled it.
Old 05-26-2014, 08:25 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Also, I would be concerned why the catalytic converter efficencybis not ready yet. Do you have aftermarket catalytics?
Old 05-28-2014, 01:27 PM
Revn29k00
Revn29k00's Avatar
I've got a 99 as well with pfaff exhaust and 997 headers. Just passed e-test last night. Drive clean center confirmed that for a 99 you are allowed 2 not ready statuses. Not sure what year it changes to 1 not ready status allowed but as Cam stated his model (997) was allowed 1.
Old 05-28-2014, 01:29 PM
P0rsch3F113
P0rsch3F113's Avatar
Guess I have this to look forward to in August.
Old 05-28-2014, 01:40 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Are you not planning to drive the car until August?
Old 05-28-2014, 02:09 PM
ronnie993tt
ronnie993tt's Avatar
Try and be more positive. Hudak might get in and you'll be off the hook.
Old 05-28-2014, 02:10 PM
P0rsch3F113
Huh? Been driving.
Valtag expires in August, and will probably need the eTest to renew.
Quick Reply: Drive Clean Test - Failed
