My Journey into Racing
Old 01-20-2017, 06:29 PM
  #31
mark kibort
mark kibort's Avatar
Originally Posted by Slakker
Awesome! What are you building?
I definitely felt like a dork after that was pointed out but at least it was an easy fix.
Bringing this up did make me think of a silly theoretical question for you though. Would there ever be an advantage to installing a wing upside down and using it to create lift? Not that I would ever do it but in my case where 65% of my weight is in the rear, is there a specific type of corner where lift would be an advantage?
Hmmm. i think i understand the question. you have most of your weight in the rear and you want the car to be more balanced in a corner? I suppose there might be some high speed corner where the balance of the car , aero dynamically was biased to the rear and you would want to lessen the down force in the rear. this happens all the time in the fast courses by lessening the angle of attack of the wing (AoA). sometimes balance of the aero wins out over sheer downforce numbers. in fact, its car and track dependent. the advantage any race car and driver has is the perfect balance of downforce, balance and drag with the HP available.
so, yes, you could turn the wing upside down in the rear (or right side up as ACE mentioned ) and get lift in the rear.. cant think of too many situations where this would be something you would want to do.. maybe drifting at 130mph around willow springs comes to mind.
Old 01-20-2017, 06:52 PM
  #32
mark kibort
Originally Posted by ProCoach
Hahaha! Good poke, ace37. Slakker, in the data world, you are looking for "downforce," and fighting against "lift," so no. There are other ways to "unstick" either end more effectively and in pursuit of a more balanced car than introducing a condition the wing (and the car body shape) is designed to combat.
What he is asking, is that are there conditions where aero changes of the rear wing can be helped by introducing lift vs downforce, and this is a common techique used by everyone trying to achieve balance of downforce. for many years, before people used wind tunnels, they used your view of "more" being "good".. this is not the case. balance is sometimes worth more.
taking wing out, is lessing downforce and that is a common practice. now, since most wings make downforce (a lot sometimes) with 0 angle of attack and there are some cars that have a lot more lift up front, reducing rear downforce is something that sometimes needs to be reluctantly done in the pursuit of balance. sure, its a hypothetical qustion by Slacker, but the real answer is that sometimes yes, lift is reduced in the rear of the car. adding lift, is not common , but im sure there are situations where that is possible
Originally Posted by ace37
Oh actually this might be interesting to you... while lift is undesirable in road racing, wings that offer high downforce often bring a penalty in added drag. One of the common causes of high drag is the use of aggressive wing angles of attack. When you set the same wing about flat relative to the airflow you'll typically get a great deal less drag than when you set it at 20-30 degrees for lots of downforce. Also, the drag penalty matters most at high speeds.
So so what quite a few clever race teams have done to gain an advantage (typically cheating) is use carefully selected wing materials that let the wing flex a bit at speed. Flex meaning the wind bends the wing shape to be a bit flatter at high speed, and the team usually has a good idea about how much this happens and at what speeds. Ergo lower high speed drag and still high low speed downforce in the moderate and low speed corners. Usually this is very subtle and hard to catch so it goes on for a while before being banned under movable aerodynamic device rules.
Yes, there is a sweet spot for drag vs downforce as we have discussed on the board before. most are in the 7-10:1 range. this means if 10:1, at some moderate wing angle (AoA), if you have 300lbs of downforce, you would have about 30lbs of drag at that speed. (put in perspective, that 30lbs of drag, at 120mph, with a 4:1 total gear ratio, would be about 8lb-ft of toruqe at the engine.) the bad part of that downforce is that it is there whether you need it or not. .. so the balance of downforce required for some turns, vs the drag down the straights, is a challenge in race car set up.
interesting that there are some techniques of materials that flex enough under aero forces, that change the shape enough to provide downforce when needed and flaten out , with those forces to reduce drag. those forces to distort are not free, so i wonder the drag effects to have such effects on the wing structure. do you have values of drag vs lift at different speed ranges for such a wing?
interesting.
Old 01-21-2017, 01:48 AM
  #33
ace37
ace37's Avatar
interesting.
Mark, here's a recent high level case - Toyota's LMP in 2014. This one is different as the wing chord stiffness itself isn't the driver, the end plates twist the wing.
http://www.mulsannescorner.com/newsjan15.html
http://www.mulsannescorner.com/newsjuly14.html
http://www.mulsannescorner.com/RCELeMans2014.html
Racecar engineering also did a short bit on it in August 2014.
Sorry, I don't know of any with hard numerical data available. It's not too hard to analytically estimate 2D airfoil chord stiffness though - to go dirt simple and intuitive you could consider a thin flat plate airfoil at 20 degrees. High aero pressure would bend it (especially near the trailing edge) to bleed off the angle of attack. If it needs to bend more just use a thinner piece of sheet metal. It can work pretty efficiently.
Old 01-21-2017, 08:17 PM
  #34
Slakker
Slakker's Avatar
Originally Posted by GPA951s
I am building an 88 944 Turbo-s.
Can't wait to see how it turns out! I'm not sure that a turbo can qualify but you should at least check into the 944cup series. The guy that runs it has been awesome to deal with on a few transactions and it sounds like a total hoot!
And as for uplift, yes, that was exactly the kind of theoretical informative but practically useless discussion I was hoping for. Thanks for taking the time to chime in guys.
Old 01-23-2017, 01:21 PM
  #35
GPA951s
GPA951s's Avatar
[QUOTE=Slakker;13901147]Can't wait to see how it turns out! I'm not sure that a turbo can qualify but you should at least check into the 944cup series. The guy that runs it has been awesome to deal with on a few transactions and it sounds like a total hoot!
Plan is start out in PCA Stock F Get some seat time, Then move to the SP3 class..
Old 01-23-2017, 01:41 PM
  #36
fleadh
fleadh's Avatar
I don't think there's any allowances in any GT rule book that'd let you run a wing upside down, but I know at tracks like Daytona it's relatively common to configure/adjust the wing (if allowed by the rules) in such a way as to create lift on the rear of the car instead of downforce (it's really not very fun to drive for an endurance race, but do you want to win or have fun?).
-mike
Old 01-23-2017, 01:43 PM
  #37
linzman
linzman's Avatar
Why not just come straight to SP3? In F, you'll be classed with other letter cars, and will be the slower car in class. In SP3, you'll be with SP1-3 , usually SBOX, and occasionally D or E cars, usually a split start ( on east coast. anyway) so you'll be at the front end speed wise. I bought my car as an E car, and switched to SP3 after the first year. Should have started there, as it was just more competitive for my 968. Those E class 911s were tough to keep up with.
Old 01-24-2017, 02:59 PM
  #38
GPA951s
GPA951s's Avatar
I have a Friend in the Club who races in "F" (Have to because of it being a turbo-s). I wanna go door to door with him here (Watkins is home track)... Then make the move to SP3..I think Ill backdate my car and put the smaller turbo on for SP3, 200 Extra pounds is not worth 30hp to me.. As it stands right now the only class I could run in Right away would be GT3 With the Setup I have on the engine stand...So I will Get my Racing License This summer and Do DE's with a REALLY fun car. I Really cant wait though! It looks like an absolute blast...
Old 01-24-2017, 06:31 PM
  #39
linzman
linzman's Avatar
Hope to see you at the glen then. Stop by, we should have at least 4 SP3 cars
Quick Reply: My Journey into Racing
