Dry bleed for brake calipers
I like the idea of no air getting in when vaccuum bleeding (and getting more cool parts on my car) but not sure what the parts pictured do.
The bottom left seems to be what you screw in where the old bleeder was.
The bottom right seems to be a plug for when you are not bleeding.
Whay's the big grey thing on top?
Hey Geoffrey, you still want some cup tires?
Basic Site Sponsor
Basic Site Sponsor
That is the female part the goes over the male brake fitting. You can either connect it to a vacuum source, or connect it to a catch can as a drain for pressure bleeding.
And yes, tell us Geoffrey, how much does it cost?
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
Mike,
Yes I do
Larry, very, very expensive. The Staubli dry break I put on my clutch line was over $200 and I would imagine these are in the same range.
Yes I do
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Originally Posted by Geoffrey
Mike,
There is a reason that the AP and Staubli fittings are so expensive - they are of exceptional quality.
A supplier tells me that if the Porsche caliper has o-ring seals on the bleeder screws the AP ones would work. Does anyone know without looking? He also says that Brembo also offer a version at an even greater cost.
CP6300-21 $152.50 each (2 per caliper)
CP6300-31 $325.00 each (you need a minimum of 2 per car and more like 4 to do it all the way)
Not quite sure what those part numbers mean, but at $2,500+ for a set up it really doesn't matter.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Brembo calipers bleeders do not use O-rings to seal, rather a tapered seat. Bleeders, however, are 10mm x 1.0.
