Polar Peter's Carrera GT Major Service
Old 03-27-2015, 03:52 PM
Plastique999
Plastique999's Avatar
Originally Posted by TRAKCAR
Sexiest thread ever. Thank you.
Agreed!
Old 03-27-2015, 05:28 PM
lsmkr01
lsmkr01's Avatar
Originally Posted by jimmyrepasi
Located in Connecticut. Porsche Of Fairfield. The Silver one belongs to a member on here also. If he wants to introduce himself and his car Im sure he will. I just finished the Major Service on that one as well and have two more inbound
Is the Major service a milage based or time based one? I know item such as clutch wear depend highly on the driver but I'm talking more overall. Great work btw, glad you're giving the community a sneak peak into the world of CGT care.
Old 03-29-2015, 10:49 PM
jimmyrepasi
Basic Sponsor
jimmyrepasi's Avatar
It is time and mileage. Here is page 4 of every Carrera GT Maintenance Manual.
Old 03-29-2015, 11:00 PM
jimmyrepasi
Basic Sponsor
The old camshafts which Porsche paid to replace
Bank 1 camshaft-less
Without the buckets and shims you can see the top of the valve and retainers
Bucket(left) and shim (right)
The new shim per adjustment needed for this particular valve lash measurement, 2.650mm
Where the shim sits under the bucket
Torquing down the camshaft caps
All torqued
Look close to see the split gear feature below
All the cam timing tools installed on the back of the engine
Old 03-30-2015, 10:56 AM
Gofishracing
Gofishracing's Avatar
what was wrong with cams? oiling problem?
Old 03-30-2015, 03:03 PM
bojali
bojali's Avatar
pitting on the Cams? or?
I just had my Major done in Nov/Dec and the cams looked good. Just wondering if there is a new campaign to update the cams.
Old 03-30-2015, 05:17 PM
CGT000
CGT000's Avatar
+1
Old 03-31-2015, 01:57 AM
jimmyrepasi
Basic Sponsor
No update but some cars do need new camshafts due to pitting. It was more common in the early cars but there isn't any rhyme or reason to it.
Old 03-31-2015, 02:59 AM
amerifrikaner
amerifrikaner's Avatar
Interesting...apart from doing a major service and opening up the engine are there any other telltale signs of pitting happening...eg can you see some metal shavings in the oil filter or collect small pieces of metal with a magnet during oil change? In the airplane world you can have a sample of your old oil collected and send for oil analysis...can we do the same with our CGT's oil at time of an oil change? Also, what is the cost for new camshafts? I would assume you would be better of doing a major service if you are going through all the trouble of opening an engine.
Old 03-31-2015, 07:56 AM
neanicu
neanicu's Avatar
Yes. It is called Blackstone Laboratories.
Old 03-31-2015, 09:46 AM
W8MM
W8MM's Avatar
The cams were replaced in my car (VIN ...1166) at around 7K miles during the major service about two years ago. It was ugly, but not nearly as bad as another CGT that was serviced about a month before mine.
Conversations with the PCNA Atlanta tech center revolved around switching to a higher zinc content motor oil, rather than Mobil1, as a preventative.
Any more recent info on oils?
Old 03-31-2015, 11:35 PM
smokeygt
smokeygt's Avatar
Default electrolysis?
I wonder if the pitting is caused by electrolysis. 2 different metals and such. In boats that are kept in the water, battery chargers cause all kinds of problems with electrolysis. They have special chargers and it is still a problem.
Old 04-01-2015, 12:04 AM
jimmyrepasi
Basic Sponsor
Before W735 Campaign
After W735 Campaign
PCCC cleaned, inspected, installed and torqued
Starter ring torqued
Release module cleaned and reinstalled
Engine back together and ready for a full detail
Back from the detail department
All ready to go back in
All new updated coil packs
Last view of this beautiful piece of engineering before tucking it back into the chassis
Engine oil drain on the left. Transmission oil drain on the right
Coarse oil filter housing
Draining the oil filter housing
Oil filter and seals replaced and housing torqued
oil drains torqued
Old 04-01-2015, 01:44 AM
amerifrikaner
I'm familiar with Blackstone...use them on my planes. Do you know if they do car oil analysis as well?
Old 04-01-2015, 01:46 AM
amerifrikaner
Answered my own question : http://www.blackstone-labs.com/services.php
Quick Reply: Polar Peter's Carrera GT Major Service
