955/957 Cayenne DIY: Opening a stuck front ashtray
Old 09-05-2013, 10:45 PM
Yorkshire_Jon
Yorkshire_Jon's Avatar
Default 955/957 Cayenne DIY: Opening a stuck front ashtray
Hi All,
I need a bit of assistance. The mrs has put her keys and a load of other 'stuff' in the ashtray, closed it and now it won't open!
I'm pretty sure it's not broken, just full of 'stuff'.
Any suggestions how I can open it? Does the radio and climate control buttons need to come out?
I've attached a photo to show the tray I'm talking about.
Jon
Sent using Forum Runner
Yorkshire_Jon is offline
Old 09-05-2013, 11:58 PM
touareg
touareg's Avatar
Stolen from renntech:
http://www.renntech.org/forums/topic...n-smoker-tray/
Remove the trim around the outside of the central stack. It is the bezel (black matte plastic in Cayenne and Cayenne S, matte silver on Cayenne Turbo). You pry from one end, it's just held in with clips.
Remove the climate controls-- these are held in with two metal spring clips, one per side. You have to use a small screwdriver to lever up and release the clips
Note to remove the climate controls, you will need the car in Drive or at least not in Park
Below this, you will find two torx screws holding in the ash tray. Remove these. The ash tray slides out. Behind is a connector to supply power to the ash tray, unhook this.
The non-smokers tray replaces the ash tray and goes in with the same two torx screws.
Push back in the environment controls until the clips snap in.
Replace the bezel.
Total time: maybe 30 minutes tops!
touareg is offline
Old 04-09-2014, 11:42 PM
drewcwsj
drewcwsj's Avatar
I've been trying for 30 minutes but can't seem to get the spring clips holding the climate control to release. I've pushed hard and tried to lever but nothing seems to work.
drewcwsj is offline
Old 04-10-2014, 09:50 PM
Kris Murphy
Kris Murphy's Avatar
I just had to do this this weekend. The clips are a pain, but stick with it. I used a medium flat head screw driver. It helped to be down low to see where the clip was. You need to get behind it, and apply a bunch of force towards the center of the unit. If you get one side out, put something behind it so it does not pop back in when you go after the other side.
Kris Murphy is offline
Seritaporchegirl (11-12-2022)
Old 04-14-2014, 08:01 AM
derekmines
derekmines's Avatar
Yep, the climate control removal was a complete pain (I too had a broken ashtray and decided to DIY the replacement) use a small torch to shine in the holes at the side of the climate unit and you should see the spring clips.... it's hard to vocalise but they weren't where I expected them to be and I wasted a good 10 minutes before getting the torch!
derekmines is offline
Old 04-14-2014, 08:28 AM
Deezenuts
Deezenuts's Avatar
mine sticks also
take a butter knife and pry it a little and it should open (mine does)
Deezenuts is offline
Old 04-18-2015, 06:54 PM
Yowzilla
Yowzilla's Avatar
This thread helped me on my first DIY on the 09 GTS.
I had the center ash tray not catching to stay closed as well. While driving I though I could dislodge the coin or mechanism to start catching when closed. Well in the process I got it to snap closed but the tray was opening so fast it could launch coins into the back seat.
I knew it was some spring or resistance that would allow the tray to open slow and smooth but did not know what I was getting into.
Anyway did the search, fought the AC spring clips till I used two flat head screw driver on the same side to work the catch loose one one side. Then as others said I left a screw driver in the disengaged side while I worked on the other.
Got the tray out and it took a little studding of the mechanics until I noticed the teeth for no reason and figured something was still in the car. I looked and felt all around with no luck ...Then got a flash light and looked real slow on the driver side of the ash tray location. Bam I saw it and it was easy to retrieve...
Snapped it all back together and now it is 100% working!!
Yowzilla is offline
Old 05-14-2015, 11:32 AM
Dilberto
Dilberto's Avatar
Default Ashtray Insert Re-assembly?
How does the insert go back together? I have no idea how the spring(broken?) re-orients itself:
Dilberto is offline
Old 09-17-2015, 10:33 PM
reachme
reachme's Avatar
I always appreciate more pictures and just went through this myself.
Had to remove an offending quarter that was preventing the ashtray from closing on an 04 CTT.
I hope this saves someone time realizing how far they need to push in AC spring clips on each side to remove. I also found it impossible to do both sides at once and in the end did not need to.
Shows the angle of the spring clip on an 04
Only two screws to unscrew-visible only when AC is removed
reachme is offline
Old 09-14-2016, 10:09 PM
two914s
two914s's Avatar
Default Almost OOOps
I was just trying to get the center bezel off of my 2006 Cayenne S Titanium Edition (has the extra aluminum trim on the bezel as does the turbo) and I almost damaged that bezel because I was prying at the wrong place. I hope these pictures of the attachment points will aid in prying well.
The white arrow shows the main metal clip that was the hardest to release.
If you dont pry right at this point, and the clip is a little stuck, you could bend the trim.
two914s is offline
Old 09-14-2016, 10:24 PM
two914s
two914s's Avatar
"torch"?
two914s is offline
stormy69 (03-28-2022)
Old 09-14-2016, 11:34 PM
two914s
two914s's Avatar
Default Porsche Cayenne Ash Tray Ashtray Spring Closeup
two914s is offline
Old 09-15-2016, 07:18 AM
wkearney99
wkearney99's Avatar
Originally Posted by two914s
"torch"?
What the English call a flashlight.
wkearney99 is offline
Old 10-21-2016, 01:33 AM
machisono
machisono's Avatar
Thanks for the great read and pics. Took about 45 minutes to complete, one third of the time looking for light and tools.
machisono is offline
Old 08-31-2017, 09:50 PM
deilenberger
deilenberger's Avatar
Received 1,144 Likes on 759 Posts
Excellent thread - moving it to the DIY forum since it's clear instructions and photos are worthy of being a DIY.. hang on..
deilenberger is offline
Quick Reply: 955/957 Cayenne DIY: Opening a stuck front ashtray
