Audio and Video Forum The place to discuss auto and home audio, home theater etc.
Sponsored By:
Sponsored By: Musicar
Radio pinout.
Old 09-16-2016, 05:09 PM
saline
saline's Avatar
Default Radio pinout.
I need to get my navigation disk out of my unit. Can I put 12 volts on it and use the eject button? If so, can someone point me to the 12 volt positive pin (assuming the case is ground)? I assume the fuse is the main power. Can I take the fuse out, put it in series with a 12 volt supply and alligator clip it to one of the fuse sockets in the radio. Not sure which one though.
Old 09-24-2016, 08:22 PM
Kevinmacd
Kevinmacd's Avatar
Not sure this is your radio, looks like it
Old 09-25-2016, 11:04 AM
saline
saline's Avatar
Thanks KevinMacd. So, I assume the lower right pin is A5?
Old 09-25-2016, 08:29 PM
Kevinmacd
Kevinmacd's Avatar
http://www.renntech.org/forums/uploa...1238202313.jpg
Old 02-17-2017, 11:09 AM
HattyDamp
2nd Gear
HattyDamp's Avatar
Hi...i am a new user here. As per my knowledge The problem with integrating all controls into a single computer controlled interface is that it can take much more time to access the feature you want, especially when the car is moving and not stationary.Simple things like climate control settings, radio on/off/volume/track selection, traction control/stability control settings, etc, are far easier to control with simple buttons and ***** than navigating through a computer interface which often makes you go through menus to get to the function you want, especially when you are actually driving.
pcb assembly
Quick Reply: Radio pinout.
