Audio and Video Forum The place to discuss auto and home audio, home theater etc.
Sponsored By:
Sponsored By: Musicar
Carputer in 2006 Cayenne issue
Old 09-08-2016, 02:14 PM
Brandon Smith
Brandon Smith's Avatar
Default Carputer in 2006 Cayenne issue
I am adding a carputer to my 2006 Cayenne TS as the navigation no longer works and the cell integration is quite archaic. I have three questions...
1) Is there an aux in on the stereo so that I can wire the carputer signal in straight?
2) I have the old cell phone in the center console that is hardwired in. Can I remove it and use the power from there?
3) I have the two 12 volt connectors that I am trying to use under the dash on the passenger side but they keep pushing my chargers out. Any tiips?
Thanks!
Old 12-04-2016, 09:29 PM
Misc3r
6th Gear
Misc3r's Avatar
No carputer installed in my GTS yet, but I've installed about 4 carputers in my lifetime through various vehicle brands
- I believe you have the BOSE system, could you confirm?
- In my experience, getting rid of the factory head unit completely makes things MUCH easier to deal with
- If you are using the BOSE system, what I would recommend would be to tap into the wires of the factory amp located in the D-pillar, to get all the source of the factory speakers, so you won't need to spend $600 on a nav-tv device
let me know!
(I have a double-din 8" Full android headunit in mine now, but it sucks tbh... I'll re-build my entire system with a 10.1" LCD and will relocate the heated seats, warning button and aitbag light at the very bottom. LOTS of refab but it will look ridiculously factory)
Quick Reply: Carputer in 2006 Cayenne issue
