997 Turbo Forum 2005-2012
Bluetooth stream
Old 03-23-2017, 09:44 AM
indesj01
indesj01's Avatar
Default Bluetooth stream
Hey all I have a 997.2 turbo S with Bluetooth for phone but was wondering how to play music through the "AUX" setting. Do I need a tookie installed to be able to stream music via Bluetooth ? Or that iPod cord installation I had on my 997.1? Thanks in advance and promise some pics to come
Old 03-23-2017, 07:49 PM
khiroshima
khiroshima's Avatar
I have been quite happy with this:
TUNAI FIREFLY: World's Smallest Bluetooth Receiver
Amazon Amazon
Nothing fancy, but it gets power from the USB and the earphone jack plugs right into the auxiliary port and that's it! Wireless streaming, straight to your PCM! Now you do lose your USB for charging, so a splitter might be necessary, but for the convenience of BT streaming, I have been quite happy with a $40 plug and play! LMK if you have any questions! KH
Old 03-24-2017, 12:13 AM
ble2011
ble2011's Avatar
Wish I had an aux port on my 997.1tt. I would do this in an instant.
Old 03-24-2017, 04:35 AM
caslca
caslca's Avatar
Not sure if this was OP's actual question, but the manual actually talks about an A2DP option. The built-in bluetooth does not do a2dp which is what you need to directly play from your phone to car. What some do is hookup a BT receiver to the aux input in the center console. Then you can select aux from "source" and you can hear audio but that's it.
A more advanced option is to pretend you have an iphone with this:
Amazon Amazon
(see https://rennlist.com/forums/997-foru...l#post10808417)
Your phone will connect to it and then you can actually see and control your library on the pcm like here: http://www.6speedonline.com/forums/9...ml#post3964933
Quick Reply: Bluetooth stream
