997 Turbo Forum 2005-2012
TranzIt BLU HF Install in a 997.1TT - PCM 2.1
Old 05-01-2014, 11:19 PM
  #61
ilko
Agent Orange
ilko's Avatar
I tried a similar one, made by FlexSmart: http://www.gogroove.com/component/vi...&category_id=2
Terrible reception half the time and lost Bluetooth connection the other half. Hated it.
Old 05-01-2014, 11:46 PM
  #62
DMoses#620
DMoses#620's Avatar
I installed mine tonight. I love this thing! Thanks for the heads up on this device. Getting the PCM out was a pain in the ***!!
Old 05-03-2014, 07:23 PM
  #63
atcbi5
atcbi5's Avatar
I am sure it works and sounds great, just taking stuff apart sucks.
Old 05-03-2014, 08:55 PM
  #64
9LVN_TT
9LVN_TT's Avatar
Taking out the PCM is the hardest part! Couldn't agree with you more on this!
Old 05-04-2014, 05:07 PM
  #65
atcbi5
atcbi5's Avatar
How is the sound guys? I would do it but the sound is what I am worried about. It must sound better than my Soundfly FM modulator. FM's freq response is limited to from 30hz-15khz. Probably will sound better since the noise floor would be lower due to the direct feed into the FM rx. Just trying to justify the purchase.
Old 05-04-2014, 07:00 PM
  #66
ilko
Agent Orange
ilko's Avatar
The sound is fine. It is as good as an FM station that comes in clear if not better.
Old 05-04-2014, 07:34 PM
  #67
9LVN_TT
9LVN_TT's Avatar
Agreed.
Old 05-04-2014, 08:59 PM
  #68
bmwtye
bmwtye's Avatar
Agreed the sound is fine. Did any of you mount the unit securely or just tuck it in. I haven't mounted mine securely and have it tucked in and I notice when hitting bumps the unit drops connection and then reconnects again.
Old 05-04-2014, 11:30 PM
  #69
ilko
Agent Orange
ilko's Avatar
Haven't had that issue, I tucked mine safely behind the PCM.
Old 05-05-2014, 10:39 AM
  #70
9LVN_TT
9LVN_TT's Avatar
Tucked mine behind the PCM (tons of room back there)....and no issues to date.
Old 05-05-2014, 03:18 PM
  #71
bmwtye
bmwtye's Avatar
Hmm, i notice if i mine is laying on the floor and say i pick it up, it drops connection. Sounds like it could be an issue with the wiring harness going into the unit.
Old 05-11-2014, 09:26 PM
  #72
bmwtye
bmwtye's Avatar
Here is a pic where I installed the mic. I have the cover removed to show. The pop in/out cover I drilled a bunch of holes in and covered with speaker grill cloth.
cbracerx (06-14-2021)
Old 05-14-2014, 04:24 PM
  #73
66mustang
66mustang's Avatar
really you should use this type of connector to install
http://www.discountcarstereo.com/TTAPR.html
Old 05-14-2014, 04:35 PM
  #74
ilko
Agent Orange
ilko's Avatar
Thank you for the advice. But I really dislike T-taps.
Old 05-14-2014, 04:38 PM
  #75
9LVN_TT
9LVN_TT's Avatar
Reason?
I insulated just as you did with elec tape and it works fine. Simply curious.
letz_go (10-09-2019)
Quick Reply: TranzIt BLU HF Install in a 997.1TT - PCM 2.1
