TranzIt BLU HF Install in a 997.1TT - PCM 2.1
Agent Orange
I have the TranzIt BLU in my 993 and love the integration with the period correct factory radio. I wanted to do something similar in the 997 but it's been a busy few months and just haven't had the time. Mind you I bought the unit over 4 months ago... Another member posted that he successfully installed it which prompted me to get to it.
Please use the install instructions that come with the BLU HF along with this DIY.
Along with the BLU HF you need a Motorola to Fakra antenna adapter for the PCM, found here: http://www.discountcarstereo.com/BAA2223.html
I won't explain how to remove the PCM, there are many good DIYs such as this one:
Now, once you remove the PCM you need to let it rest on a soft surface. A green towel works best:
![Name: C12AE6AF-D0A7-4958-9EA3-5718F867ACD4_zpsjcsjhibl.jpg
Size: 94.7 KB](https://rennlist.com/forums/attachments/997-turbo-forum/1204916d1501318166-tranzit-blu-hf-install-in-a-997-1tt-pcm-2-1-c12ae6af-d0a7-4958-9ea3-5718f867acd4_zpsjcsjhibl.jpg)
In the photo below you can see the wiring harnesses and antennae. You need to remove the black antenna on the left and then use the Motorola to Fakra adapter:
![Name: E27C0C86-0F37-4D80-B905-D054193480C7_zpsnn0r0wez.jpg
Size: 85.7 KB](https://rennlist.com/forums/attachments/997-turbo-forum/1204917d1501318166-tranzit-blu-hf-install-in-a-997-1tt-pcm-2-1-e27c0c86-0f37-4d80-b905-d054193480c7_zpsnn0r0wez.jpg)
![Name: FEF08B15-7789-46C7-8C49-D290CFB3A50C_zpszwuloy3z.jpg
Size: 91.7 KB](https://rennlist.com/forums/attachments/997-turbo-forum/1204918d1501318166-tranzit-blu-hf-install-in-a-997-1tt-pcm-2-1-fef08b15-7789-46c7-8c49-d290cfb3a50c_zpszwuloy3z.jpg)
Then you need to tap into the PCM wiring harness - ground is brown, accessory power is white:
![Name: A8D107E6-43C6-4525-9C54-2AD4C9B932F1_zpsnrbzltuj.jpg
Size: 106.4 KB](https://rennlist.com/forums/attachments/997-turbo-forum/1204919d1501318166-tranzit-blu-hf-install-in-a-997-1tt-pcm-2-1-a8d107e6-43c6-4525-9c54-2ad4c9b932f1_zpsnrbzltuj.jpg)
Wires connected:
![Name: 32E0A14E-903C-4D93-97AF-383836256995_zps6yfmsdjx.jpg
Size: 129.5 KB](https://rennlist.com/forums/attachments/997-turbo-forum/1204920d1501318166-tranzit-blu-hf-install-in-a-997-1tt-pcm-2-1-32e0a14e-903c-4d93-97af-383836256995_zps6yfmsdjx.jpg)
And insulated:
![Name: DEE4F67F-3C1D-4B6D-9965-D741407843C4_zpstbfdk0hm.jpg
Size: 147.3 KB](https://rennlist.com/forums/attachments/997-turbo-forum/1204921d1501318166-tranzit-blu-hf-install-in-a-997-1tt-pcm-2-1-dee4f67f-3c1d-4b6d-9965-d741407843c4_zpstbfdk0hm.jpg)
Other types of connectors also work but I prefer the above method.
Now it's time to put the PCM back in and route the cables behind it. Thankfully there is plenty of space!
![Name: ACA6C513-7B69-45C0-B82D-D399EBDDBD6E_zpsj3eqtlwa.jpg
Size: 84.5 KB](https://rennlist.com/forums/attachments/997-turbo-forum/1204922d1501318166-tranzit-blu-hf-install-in-a-997-1tt-pcm-2-1-aca6c513-7b69-45c0-b82d-d399ebddbd6e_zpsj3eqtlwa.jpg)
I decided to put the green button next to the steering column for a more stealthy look:
![Name: 1EDA4E85-47E4-478D-9C9D-A071CF393010_zps5xe8yvcd.jpg
Size: 84.9 KB](https://rennlist.com/forums/attachments/997-turbo-forum/1204923d1501318166-tranzit-blu-hf-install-in-a-997-1tt-pcm-2-1-1eda4e85-47e4-478d-9c9d-a071cf393010_zps5xe8yvcd.jpg)
And here is the finished install:
![Name: F1BC3396-9223-45A7-9576-58129D546B07_zps0gw8nhxp.jpg
Size: 84.5 KB](https://rennlist.com/forums/attachments/997-turbo-forum/1204924d1501318166-tranzit-blu-hf-install-in-a-997-1tt-pcm-2-1-f1bc3396-9223-45a7-9576-58129d546b07_zps0gw8nhxp.jpg)
Took me about 1.5 hours at a very leisurely pace including routing of the microphone to the sun visor.
The sound quality is good, the TranzIt is very easy to use and it doesn't require any coding, or other crazy things.
Any questions, do let me know!
Wires connected:
And insulated:
I went ahead and purchased this. Should be here this week. I am hoping to install it by end of next week. I'll post my feedback here.
Thanks again Ilko for the review and write up!
Installed mine over the weekend. Hardest part for me was getting the PCM out. The retaining aluminum pieces did not fully retract when turning the cams, had to use my fingers to push them the rest of the way in. Otherwise, was fairly simple install. The unit works as described, calls are clear, music streams nicely. Great product for the price vs. other aftermarket options. 100 bucks plus a few hours installing it.
Ryan
Ryan
