997 GT2/GT3 Forum 2005-2012
GT3 wheel center caps
Old 02-23-2017, 02:31 PM
DWNDRAFT
DWNDRAFT's Avatar
Default GT3 wheel center caps
Ordered 2 new ones, and these came. Silver color is different than the 4 I have on the car, new one also have black GT3 letters. Part no. Is the same...
whats the deal, which is correct?
Old 02-23-2017, 02:56 PM
boostedt0y
boostedt0y's Avatar
My OEM caps look like the one on the right with the black lettering. It looks like the caps on the left were resprayed.
Old 02-23-2017, 03:36 PM
bmwtye
bmwtye's Avatar
Left caps were painted.
Old 02-23-2017, 10:19 PM
jacksojf
jacksojf's Avatar
Right one matches my '07.1 GT3.
Old 02-23-2017, 11:17 PM
Rick GT3
Rick GT3's Avatar
mine too, also bought new ones over 1 years ago and were basically the same as the right ones.
Old 02-23-2017, 11:26 PM
abcut973
abcut973's Avatar
It is obvious the cap on the left has been painted.
Old 02-24-2017, 04:52 AM
DWNDRAFT
DWNDRAFT's Avatar
You are very likely right, I will try a scrape thru the paint to conclude later today. Guess I need 4 new ones to satisfy the OCD...
BTW. Is there any good way to clean or refresh the grey/purple-ish center lock nut finish (anodized)?
Old 02-25-2017, 03:55 PM
DWNDRAFT
DWNDRAFT's Avatar
yup, they are painted over... New set ordered.
took all 4 CL nuts apart to clean, inspect and re grease as to spec. Happy to see no wear marks at all on cone and washer.
CL finish cleans up nice using WD40 and MF cloths.
(btw it also disolves optimol grease really easy, something to note of cleaning the nuts occasionally between CL service)
Old 02-27-2019, 02:23 PM
sirtom
sirtom's Avatar
So you repainted the nuts silver? How did you do it without losing the writing / markers on the centerlock nuts?
Are those markers needed for anything other than a point of reference? I may anodize mine to another color, and was wondering if losing all markings would be an issue for anything.
Old 02-27-2019, 03:32 PM
DWNDRAFT
DWNDRAFT's Avatar
I did not paint anything, I cleaned the CL nuts and got new new center caps.
The scale around the nut is to tighten the wheel at road side without a tq wrench at hand, as I understand it.
Old 02-27-2019, 06:42 PM
bweSteve
bweSteve's Avatar
Received 1,040 Likes on 660 Posts
.... soooo, were your rims also painted the same as your center caps? ... I'm guessing that since you did not know (that your caps were painted), that the colors matched between caps & rims... hence my question.
=Steve
Old 03-05-2019, 02:26 AM
globed
globed's Avatar
The CL nuts can be bought in grey, red, and black... I saw a post some years back of a GTS owner who anodised his red, they didn’t look anything like the factory - his attempt looked cheap. I’d personally pony up for the factory set. My two cents.
Old 03-05-2019, 10:37 AM
gt2-josh
gt2-josh's Avatar
I've never owned a 997.2 but my CGT was delivered with different color nuts on each side. That may be what byeSteve is referencing. JBO
Quick Reply: GT3 wheel center caps
