997 GT2/GT3 Forum 2005-2012
Lug nuts for 997 GT3.1 HELP
Old 11-20-2016, 01:51 AM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,829 Likes on 2,389 Posts
put wheel on car
take it off jack stands
get it to tony colichio
u will have less white hair, i presume you still have hair ;-)
Old 11-20-2016, 01:54 AM
gt2-josh
gt2-josh's Avatar
xxx
Old 11-20-2016, 01:56 AM
mooty
mooty's Avatar
my last set of perlon CGT seats are in my 4.0
it can be had for $750k usd.
you get the seats and i throw in the car too. win win.
Old 11-20-2016, 01:58 AM
gt2-josh
gt2-josh's Avatar
How about $750 and my CGT seats. The last car I spent that kind of money on was the F40. C'mon Mooty. Help a brother out
Old 11-20-2016, 12:05 PM
RAudi Driver
RAudi Driver's Avatar
Received 2,986 Likes on 1,770 Posts
Originally Posted by balefire
Don't mix the long lug bolts without a spacer. Don't run the short lug bolts with a spacer either. You are asking to be another YouTube viral video as I posted in the other thread.
I don't see any harm with running the slightly longer bolts with no spacer. The only issue would be if the bolts came out the back of the rotor and interfered with another part f the car, preventing the wheel from turning. That happened on my RS4 where I removed the 10mm spacer and forgot to changed for the shorter bolts. The wheels wouldn't turn as the bolt ends came in contact with the spindle and prevented the wheel from rotating.
Old 11-20-2016, 12:27 PM
gt2-josh
gt2-josh's Avatar
Yeah, my car doesn't seem to have any problems and it appears the long bolts have been on the car for awhile. Like I said I'm assuming the spacers are gone because the car is super low and even with stock tire sizes and plenty of negative camber I'm super close to the fenders. Thanks again to all. Love this place! Best JBO
Old 11-20-2016, 03:03 PM
996FLT6
996FLT6's Avatar
Just FYI. Whether or not 997 gt3 or 996 gt3 are one and the same. For some reason doing a trackday at thill after 1st session lost all 4 special key lugnuts because they were not trq'd at at all by my mechanic during pre prep (**** happens). I towed the car there with my 955 pepper s. The lugnuts were the same for the 6gt3. Keep tracking : ). Mike
Old 11-20-2016, 03:06 PM
gt2-josh
gt2-josh's Avatar
There are two separate size lug nuts for the 997 GT3. If there was only one size I wouldn't have wasted folks time. Once again I'm grateful to the community. Best JBO
Old 11-22-2016, 08:47 PM
P.J.S.
P.J.S.'s Avatar
studs and nuts -- forget this wheel bolt nonsense -- msi stud sized to fit stock and bbs and never look back
Old 11-22-2016, 09:37 PM
mooty
mooty's Avatar
^ i dont think josh likes the visual impact of those yellow nuts from msi
Quick Reply: Lug nuts for 997 GT3.1 HELP
