Center Lock Tool Removal
This may be a dumb question but need help getting the center lock tool removed from Precision Instruments torque wrench.
After a few months of ownership was thrown into the world of the center locks when I had a slow leak. Removed and put the wheel back on with no problem but now I cannot get the tool to come off the torque wrench. I believe I may have put the tool on the torque wrench with the pin on the wrench in the wrong position.
A large flat head screw driver in-between the socket and the wrench head base will allow you to pop it off.
I keep a 16P nail in my storage case allowing me to depress the pins in the handle for easy separation. Good Luck.
Precision torque wrench/ breaker bar issue
So...I bought the prec instr 600F like most in a kit that has the braker bar optiom.... 36h xxxx.... anyway.i can't figure out how to attach that bar to make it a beaker bar.... do I need another adapter like it has at the head to attach that bar in place of the bar that measures/ clicks???
jjrho, I helped a friend sell one of those the other day. I think the ratchet part of the wrench set just fits in it....not sure it's really even long enough to break the CL's loose though??
