997 GT2/GT3 Forum 2005-2012
DIY - oil level sender / sensor - fixed>>
Old 05-31-2014, 03:17 PM
andrewgt3
andrewgt3's Avatar
Default DIY - oil level sender / sensor - fixed>>
It wasn't fun, but it's done and the engine didn't have to come out.
#15 in the image below.
You'll need:
+ oil level transmitter - PRT# 99660614000 (~ $80 at the time of purchase)
+ 10mm socket or wrench
+ 8mm socket or wrench
+ skinny arms and a good back
Open the engine compartment. That's it with the wires plugged into it - way the hell back there.
Start by unscrewing the bracket that holds the oil filler. Unscrew this nut - 10mm.
Unscrew two more bolts - 8mm. Shown below is the lower bolt. I couldn't get a good picture of the upper bolt, but it's there under the 10mm nut.
Unplug the MAF connector.
Pull up and slip off this solenoid that is connected to the bracket you're removing.
Pull the bracket out.
Now there's a little more room. This is the tricky part. Unscrew the bolts holding the oil filler and oil sender in place. There are two 8mm bolts (#28 and #24 in the diagram above). I used a small wrench and it took forever as there's not a lot of space. The oil filler and sensor will both come out at this point.
I disconnected the sensor from the connector and plugged the holes with a couple of towels.
Old on the bottom, new on top. #4 in the diagram needs to be removed from the old sensor and screwed on to the new one.
It was stubborn, so it got the rubber hammer.
Swapped.
New sensor in place.
Reinstall in the reverse order.
Went for a quick drive to heat the car up. With the engine running on a level surface I tested the oil level and found it to be a little low. This is the first time the sensor has displayed anything but empty or full. I put half a quart in and now it's in range. Hope this helps those that have erratic oil levels.
dak996 (08-02-2023)
Old 05-31-2014, 07:08 PM
Fisher
Fisher's Avatar
Bravo! Thank you Andrew.
Old 05-31-2014, 07:29 PM
Seeeu911
Seeeu911's Avatar
Nice write up with photos. Good bit of info learned reading this. Thanks.
Old 05-31-2014, 08:01 PM
andrewgt3
andrewgt3's Avatar
Glad I can help. Here's the original issue:
https://rennlist.com/forums/997-gt2-...el-sensor.html
Old 06-02-2014, 11:09 PM
Space Coast GT3
Space Coast GT3's Avatar
Wow... Thanks for sharing!
Old 06-03-2014, 11:27 AM
Alan C.
Alan C.'s Avatar
Thanks for taking the time to post the photos and detailing the steps.
Old 06-03-2014, 10:34 PM
augustxke
augustxke's Avatar
Nice work, thanks for the info.
Old 07-03-2015, 07:09 PM
Bob996tt
4th Gear
Bob996tt's Avatar
Default Thank you
Amazing!! Thank you so much for posting the oil sender procedure. I was so lost without your help.
Old 07-04-2015, 04:36 PM
Bob996tt
4th Gear
Bob996tt's Avatar
A little different on the 2001 turbo, but couldn't have done it without your post. Thank you. Bob
Old 12-22-2015, 01:40 PM
Speeds5
Speeds5's Avatar
Thanks for this. It was really helpful. One additional picture of the other screw that's not pictured above. Took me a couple of min to find it.
Old 07-16-2016, 05:31 PM
poker2009
2nd Gear
poker2009's Avatar
Is this the same procedure for a February 2005 997 C2S, or is the sender located in a different place? The oil temp needle is stuck at 60 degrees, and occasionally jumps up, but wont stay there - so assuming this is the faulty part.
I believe the part number I will need for my car is 996.606.150.01
There is not much info out there on replacing this sensor, and I was lucky to stumble across this!
Old 10-20-2018, 11:21 AM
shadow993
shadow993's Avatar
Thank you!!! Mine crapped out this week
Old 03-14-2019, 11:44 AM
mffarrell
mffarrell's Avatar
You'll need:
Swapped.
I know this is an old thread, but did you have to drop the engine a few inches?
Thanks!
dak996 (08-02-2023)
Old 03-15-2019, 10:22 AM
andrewgt3
andrewgt3's Avatar
nope!
dak996 (08-02-2023)
Old 03-25-2019, 11:54 AM
mffarrell
mffarrell's Avatar
Did you have to drain the oil tank before replacing the sensor?
Thanks!
dak996 (08-02-2023)
Quick Reply: DIY - oil level sender / sensor - fixed>>
