Local sears hardware and tool store is closing and everything's on sale. I have a pretty comprehensive set of tools having worked on BMWs and VWs (street and race) for many years. Anything you recommend getting that is unique to Porsche and/or 997? That one little thing that makes that pain job less painful?
I also have the Torx set from Craftsman, same as Kellen. It's worth watching for seasonal offers as I bought mine in a sale for $30 (same cost as buying a set of torx driver sockets).
The Sears by me has dozens of those kits for 30% off
Timing chain Cam lock tool (won't find it at Sears though)
AirLift system for evacuating and refilling the coolant system when you do a water pump change
Motive Power Bleeder
Guide pins that thread into your Lug bolt hole allow you to slide a wheel away from the hub and caliper so you don't drop the wheel on your rotor when you remove the last bolt
3. Motive Power Bleeder
4. Guide pins that thread into your Lug bolt hole allow you to slide a wheel away from the hub and caliper so you don't drop the wheel on your rotor when you remove the last bolt
