Replacing Coolant / Engine Temp Sensor in 2005 997 C2S
I'm going to renew the engine temp sensor in my '05 C2S, which checks the temp of the coolant. The replacement came with a new metal washer but I was wondering if I need to treat the threads with anything when installing the sensor, like Teflon tape, high-temp gasket silicone, or something else in order to prevent leaks through the threads. I didn't know if the sensor threads needed to make contact with the metal housing it's screwed into for the sensor to work correctly.
Thanks.
Thanks.
