Gundo Hack "REVERSE"?
Can a Gundo hack "Muffler Bypass" be reversed? if I get the Gundo hack and later down the line I want to put back to stock can this be done?
Thanks in advance,
Steve
Thanks in advance,
Steve
Sure but it will look like a bloody mess. They have to chop off the bypass pipe and saddle weld some plugs in the holes. Trust me....you will not want to reverse the hack.
No droning brother. You'll love it. If you have 997.2 you'll want to bypass the rear muffler as well.
You're right about the PSE. There is the same type bypass pipe with a vacuum actuated valve. Push the PSE button and the valve opens allowing the bypass. Fister uses a 1.75" bypass pipe which may be bigger than the PSE bypass. Take a look at this link for more information: https://rennlist.com/forums/997-foru...undo-hack.html
"Wack without the Hack"
Official Rennlist Snake Slayer
997.1's - do the hack for better (louder) sound - these cars only have the two side cans.
997.2's - replace the center silencer with the X pipe - I'm not aware of anyone hacking the side cans, too, but you could. Usually, getting rid of the center silencer satisfies most folks. These cars have 3 mufflers - the center silencer, and the side cans.
2 different animals depending on cars.
I installed the crossover pipes first and did not hear much difference in the sound. When I added the Gundo Hack the sound really woke up. I get compliments all the time on how good the car sounds. There is absolutely no interior drone at any RPM.
Check your data. The side cans are the mufflers that are modified with the Gundo Hack. I don't recommend the x pipe. The x pipe has a tendency to sound good but it kills low end torque (according to either Sharkwerks or AWE, can't remember which) while the crossover pipes provide a slightly different sound but do not affect low end torque. The stock center muffler has two sharp internal bends in the flow path. The crossover pipes eliminate this and provide a straighter pathway for the exhaust to travel.
Here is a pic of my Tubi exhaust, where you can see the crossover/x-pipes that eliminates the center silencer on 997.2's. You can also see the side cans that were also replaced with the Tubi cans.
