Oil overfill or bad sensor?
Ok so I just purchased a 05 911 and I love it, I just wish I had done a bit of research before I took it to the local shop for an oil change. There isn't a porsche dealer in the entire state of Arkansas so that was out of the question. Here's my issue...
After the oil change I noticed smoke and I don't remember any from before the change. Once it's going and warmed up the smoke stops. I hear that it could be caused by oil overfill so I checked the level via dash gauge and it was pegged out so I took it back to have them drain oil. They took off the oil filter 2 times with a start in between and said they drained about a quart. When checking the oil gauge there is no change in the level. So I'm wondering if maybe they still need to drain more oil or something could be wrong with the sensor?
The car is in showroom condition so I wouldn't think there would be a sensor failure.
I am very worried about this issue (I've even had bad dreams about it) I just need help from someone that knows what they are doing.
Stop at say a 1/2 to 1 quart short of what the owners manual says the capacity is and then start engine let it idle and take an oil reading. If the reading is in agreement with the amount of oil added to the engine then add more oil to bring the level up to near the max line. It should take no more then 1/2 to 1 quart (max) to arrive at max level.
If the reading is *not* in agreement then there is an oil level sensor problem.
I would not drain the oil out in increments just in case the sensor is faulty and always reads "full".
The only way I know -- without access to special equipment -- is to drain the oil then add a known amount and check against the sensor/display.
Sincerely,
Macster.
As was adviced - add up 7 quarts of oil back after you drain it all out and measure oil level. If it still shows you all bars - your sensor is to be blamed.
Engine oil filling capacities: Engine oil 997 − 3.6 l Filling capacity without oil filter 8.00 litre; Engine oil
997 − 3.6 l Filling capacity with oil filter 8.25 litre; Engine oil 997 S − 3.8 l Filling capacity without oil
filter 8.25 litre; Engine oil 997 S − 3.8 l Filling capacity with oil filter 8.50 litre
Above data is from workshop manual. As you get oil in quarts - 1 quart is 0.9463 liter so you are safe measuring it 1:1.
it's the oil sensor
looks like its the oil sensor. I followed the advice and after 5 qts it still showed full bars. So we went ahead and put the other 3qts in and called it a day. I still am wondering about the white smoke, but as I've read in other posts that seems to be normal especially during lower temps. I did notice a little water in the tail pipe, so maybe I'm just worrying about some water vapor burning off at startup?
I will change out the oil sensor in about a month or so since I'm sure they got the right amount of oil in this time. (I stool there and watched) I'm waiting on the oil sensor since this oil change fiasco has cost me about $200 so far.
Any ideas on how difficult it is for the oil lever sensor to be changed out?
I tried multiple readings and with different levels of oil. The gauge never changed from showing full bars. Does anyone know if an 05 997 have a hidden dipstick somewhere?
Good idea. No kidding. Probably can't hurt. Owners manual explains the simple procedure: follow it. There should be no fears when replacing a battery (or in this case disconnecting and reconnecting). Might fix things. After a disconnect the PSM might indicate a "malfunction" but can be reset (check manual).
