I have Satellite Radio in my 997 C4S Cab!
Old 12-14-2012, 02:28 PM
  #481
mudman2
Moderator !x4
mudman2's Avatar
Music = iPod
Sat = Howard / NFL / News
Pandora = not for me
Old 02-12-2013, 07:22 PM
  #482
DELREYCUSTOMS
Former Vendor
DELREYCUSTOMS's Avatar
Default alpine nav upgrade
On most 2002+ vehicles we can do a full PCM upgrade with a new alpine navigation iPod dvd in motion Bluetooth stream audio and hands free Sirius all touch screen with keeping the factory Bose system fully operational and retain Steering wheel controls for around 2500.00. Just an idea and it controls iTunes and pandora via stream audio.
Old 10-14-2013, 08:59 PM
  #483
too tall
too tall's Avatar
I've got to ask. Who on the east coast / New England can perform the same work that DelRayCustoms is doing? I've got a 2007 911 that would LOVE satellite and bluetooth, I would not mind it either
Old 12-06-2013, 07:54 PM
  #484
DrPhilH
7th Gear
DrPhilH's Avatar
in morristown nj the finishing touch
Old 01-17-2014, 05:12 PM
  #485
tbrom
tbrom's Avatar
I have read all this about the XM radio install - so at what point or year did Porsche put the satellite ready stereo in the car from the factory? Are they in the 2009 model? Anyone know? -
Old 02-18-2014, 01:04 PM
  #486
larrytrk
larrytrk's Avatar
Yes, 2009 on. My 09 S has it(XM). It can be added for additionl cost, I believe in 09 on.
Old 08-20-2014, 11:38 AM
  #487
lic265
lic265's Avatar
I installed an Alpine head unit in my car about a year ago. Mounted the antenna under the plastic cowl near the wipers. Sat radio drops out frequently, much more than any other car i have owned. I am ready to cancel the service it is so annoying
Does not seem that there is a "sat radio booster" that one can install inline
So: Where else to mount the antenna? Will it help?
Old 09-01-2014, 09:05 PM
  #488
Dennis C
Rocky Mountain High
Dennis C's Avatar
Received 1,550 Likes on 970 Posts
The Sirius XM satellite antenna on my 996 was mounted on the front bumper, completely concealed underneath the bumper cover. It worked very, very well. I suspect it would work in a 997 the same way.
Old 03-09-2015, 01:12 AM
  #489
Babakazoo
Babakazoo's Avatar
Default SiriusXm Antenna "Fixed" by La Jolla Audio
I had an aftermarket stereo, nav, bluetooth installed and it wasn't done right where I purchased and had installed. I went to La Jolla Audio and they showed me the dramatic errors that were created on the first install. They cleaned up the mess and my Sirius pumps clearly with no cutouts.
The gps and siriusxm antenna were First placed on the driver side under a metal bracket. The proper setup should be passenger side under the plastic/nylon piece directly under the wiper. The installer should take the time to place and ground the gps and antenna directly Under the wiper, this takes an extra 30 just to remove the plastic piece...
I now have No cutouts after having my radio cutout every 45 sec - 1min. I "used" to have to run Pandora and Sirius through my bluetooth... that sucks because i would have to be on my phone to change.
Bottom Line: go to an installer that takes their time and doesn't cut corners. If you are near San Diego, just go to La Jolla Audio (sorry for the plug, but these guys are the best).
Yes and No
Old 12-17-2016, 01:43 AM
  #490
captainbaker
captainbaker's Avatar
Since this is a sticky and alternatives are good. Member Texrex2 came up with a way to add Sat radio for about $80 and an hour of your time. Its about as hard to change brake pads........in other words easy peasy. In a nutshell its the Sirius reciever, sat antenna and a special cable that tapps into your FM antenna in the back of the PCM. You tap power from the cig lighter in the passenger footwell. Turn it on and find the radio station on your stock radio where the XM signal is the strongest.
https://rennlist.com/forums/997-foru...the-cheap.html
Old 12-17-2016, 07:46 PM
  #491
alan111
alan111's Avatar
I also installed an OEM retrofit of Sirius XM in my 997.1 all for under $300. I did it myself and it was very easy. All setup in the frunk. It worked with the native PCM display and controls. I actually bought an extra tuner and have it listed for sale here (also with other part numbers to complete the retrofit)
https://rennlist.com/forums/parts-ma...tallation.html
Below is an image of how it looks with OEM integration on the PCM.
Old 12-18-2016, 01:54 AM
  #492
captainbaker
PM sent. Ill take it. BTW I like the coco, nice.
Old 12-18-2016, 02:04 AM
  #493
captainbaker
Alan, can you post up links or sources for the other required parts to complete. It seems the part numbers are outdated or invalid.
Thanks,
Christian
Old 12-19-2016, 10:55 AM
  #494
alan111
alan111's Avatar
Thanks,
Christian
Hi Christian,
You only need 4 parts including the Sirius/XM tuner.
1) SIRIUS/XM TUNER: 7L5910563 / 7L5 910 563
2) MOST/ELECTRICAL HARNESS: 955.044.900.80 - you can get it from your dealer.
3) SAT RADIO ANTENNA: https://www.amazon.com/gp/product/B000E7WI0O
4) SAT RADIO ANTENNA SPLITTER: https://www.amazon.com/gp/product/B0002GOH42
I followed instructions from a renntech tutorial: https://www.renntech.org/forums/tuto...orsche-997-c2s
Just in case the hyperlink above gets messed up - here is the link (just remove the space after renntech)
https://www.renntech. org/forums/tutorials/article/13-sirius-installation-instructions-porsche-997-c2s
Old 01-13-2017, 08:28 PM
  #495
boomer8800
8th Gear
boomer8800's Avatar
Just did this to my 2008 last week and love it.. thanks for all the info, ended up buying a old xm tuner on ebay for $100
Quick Reply: I have Satellite Radio in my 997 C4S Cab!
