996 Turbo Forum 1999-2005
My 996 Turbo Maintenance so far...
Old 02-14-2017, 09:51 PM
TommyT
TommyT's Avatar
Originally Posted by Jferrante
dumb idea - drive it
Agree totally. No matter how much if any it goes up in value, the drive is priceless.
Old 02-14-2017, 09:56 PM
mark_schnell
mark_schnell's Avatar
Hey now, I can enjoy it 40 miles a week worth and still be happy. 😎
Old 02-15-2017, 01:15 PM
bw1999
bw1999's Avatar
Old 02-15-2017, 01:16 PM
bw1999
bw1999's Avatar
Originally Posted by 911mhawk
Go to mycarfax.com and you can input what you do and some other shops may too. I've put a few vehicles in there; it's all in one place, can be accessed anywhere and printed too.
Any chance you would send me the file, even without info entered, so I can see how you did. Would be much appreciated.
Old 02-15-2017, 03:42 PM
Third-Reef
Third-Reef's Avatar
Here is my maintenance log I keep in InkPad on my cell phone
02 996 turbo X50
Tires 225 45 & 295 35 18 extreme contact dws
11/19/15 replace K&N AF with stock paper filter, check Pentosin level in clutch res.
11/15/15 boost leak check, fh fsix fuel pressure vac hose that was disconnected, clean MAF and throttle body. We
11/20/15 swap MAF sensor with known good one, no change.sta w
12/21/15 check Pentosin levels n clutch resw.
11/22/15 4 48,796 oil change mobile 1 0-40 euro formula Mann filter
12/6/16 stuff sub enclosure with polyfill, add extra insulation under sub.
12/20/15 45,600 Trans oil change with liquid moly 75w90
2/23/16 50,400, replace wastegate actuator rods and ballance wastegates at 14 psi, full brake flush motul rbf600, change front diff oil with liquid moly 75w90, tighten waste gate rods 2 turns.
1/26/16 install Kenwood DDX593, POS, has bad buzz in speakers
1/29/16 Install new heater core, lube wiper assy pivots.
2/1/16 Install Pioneer AVH-X3800BHS, Works great, awsome HD Radio, and BTz do Keurig like phone.
2/10/16 51737 ballance all four tires
2/14/16 52100 oil and filter change M1 5w-50
2/27/16 Replace Key battery cr2032l
3/21/16 installed Micro bypass, ebrake bypass
3/25/16 53,950 replaced spark plugs with Bosch FR6LDC.
3/28/16 53,975 replace battery with duralast platinum H7 AGM
4/10/16 tighten and loctite coupling on spoiler drive motor, fill and bleed system with pentosin/Lucas stop leak mix
4/18/16 Pulled front wheels undid tie rods and rotated struts and checked for binding. Found none. Injected gear lube in tie rod ends ball joints and radius rods.
5/6/16 removed front bumper, cleaned radiators, resealed both side radiators by crimping end caps, stiched left front wheel liner back together with tie wraps.
5/10/16 installed Ti lug bolt set
5/15/16 Aligned front wheels, camber at -1.0 toe out at 30'. Changed toe in to 5'. Note a clunk in left front inner tie rod end
5/20/16 measured exhaust Resonance at 107Hz and 2100 and 129 Hz and 2600
5/21/16 checked spoiler micro switches and bottom one missing metal spring leaver
5/30/16 replace inner tie rod ends and boots
6/18/16 57,700 add 1 qt 5-50 7/10/17 158350. Oil change with Rotella t6 5w-40
7/10/16 thru 7/15/16 Cobb access port from Sambo start with OTS stage 1 tune then Datalog, load Sambo stage2,
Log and then v1, log then v2,log then v3 log. Looks good, off to Laguna Seca.
8/8/16 61040, replaced clutch accumulator .
8/11/16 install smoked side marker lights.
9/21/16 replaced both pre-cat O2 sensors
10/8/16 replace Spoiler micro switches
10/17/16 replaced water pump, belt, thermostat and coolant (audi), also new exhaust flange gaskets and bolts. Pinned 6 of 8 coolant lines, did not do the two under the oil cooler.
10/30/16 64,300 oil and filter change Rotella T6 5w40. New air filter and cabin filter.
12/29/16. 65,452 Installed RS motor mounts from sun coast porsche.
Old 02-15-2017, 05:15 PM
911mhawk
911mhawk's Avatar
I didn't create a file, just use the cloud.
Go to the site, input a car with VIN and you'll see real quickly how it works.
Old 02-15-2017, 05:40 PM
Dock
Dock's Avatar
Originally Posted by mat59
How have the rest of you compared to myself in terms of mechanical failures?
I've owned my '02 since new, and with over 46k miles now on the car I've only had to replace both front wheel bearings, and the headlight switch. The OEM DVs were replaced with Bailey DVs under warranty.
Old 02-15-2017, 06:59 PM
Kevinmacd
Kevinmacd's Avatar
Originally Posted by docboy
Mind me asking how you decided the fix the carbon fiber strips on the front defroster trim? One of mine has cracked and other has delaminated. Did you get new trim, or go another route? Thanks.
The strips pulled away from the leather defroster trim. First time replaced with a set on ebay, second time around, took it all off and used gorilla glue to glue it down. The key with gorilla glue is to dampen both areas to be glued. So far so good
Old 02-15-2017, 09:14 PM
gophaster
gophaster's Avatar
This is how I do it as well. I have a simple text file that I enter the date, miles, what was done, part numbers, etc. I have the text file in my DropBox so that I can review and/or edit from any device/any where Then I file away the receipt and usually cut the label with part number/description and file as well.
02 996 turbo X50
Old 02-15-2017, 11:21 PM
treeman911
treeman911's Avatar
Interesting.
Purchased my 2003 X50 Turbo October 2015 with 13,700 miles.
I now have 23,200 miles on it and following expenditures:
2 oil changes with third one coming up.
Will need rear tires soon but enjoying the drift for now.
PPI when purchased was perfect and the car has never seen rain or snow and never will. I have never tracked the car but do run it hard. The car is a true joy.
Old 02-17-2017, 02:32 PM
bw1999
bw1999's Avatar
Appreciated
Old 09-22-2017, 07:51 AM
Silvestron
Silvestron's Avatar
where the instrument cluster was repaired?
Old 09-27-2017, 12:50 AM
peritus
peritus's Avatar
2005 Turbo S
2 summers, bought at 47,000 kms, 51,000 kms now
4000 kms of use:
4 Pilot Sport
changed ALL fluids
plugs as per maintenance schedule
tail light on spoiler
I'm at about a buck per km so far LOL. $1.25 per km if I include gas, road tax, insurance, winter storage.
That's pretty good value for money right there!
Quick Reply: My 996 Turbo Maintenance so far...
