996 Turbo Forum 1999-2005
Random Battery Failure Experience
Old 03-28-2017, 10:49 PM
  #91
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,247 Likes on 1,446 Posts
Originally Posted by cwilt
That pulled up. Nice deal but it looks like you have a 2005-2006. Mine is a 04 so I'm not sure that would work. Thanks for sharing the info.
It will fit perfectly. The only thing that changed is the newer version puts out more amps. 120 vs 150.
Old 03-28-2017, 11:17 PM
  #92
"02996ttx50
"02996ttx50's Avatar
i wouldn't buy a reman alt for my porsche. this from a guy who will save whenever/whenever i can.
Old 03-29-2017, 12:24 AM
  #93
cwilt
cwilt's Avatar
Originally Posted by Carlo_Carrera
The only difference is the pulley. The alternator for 6 speed manual cars has a clutch pulley so the belt will not bind during high RPM shifts. The Tip version has a solid pulley.
Thanks Carlos,
Do you know if it is OK to have the manual version in a tip? Or do you need to change the pulley? I have a tip.
Old 03-29-2017, 10:14 AM
  #94
Carlo_Carrera
Thanks Carlos,
It is total okay to use a manual version with a clutch pulley on a Tip.
But do not use a Tip alternator with a solid pulley on a manual car.
Old 04-03-2017, 07:42 PM
  #95
mfanatic325
mfanatic325's Avatar
A couple weeks in, and so far everything's been fine.
Shameless plug, I went to the theaters last week, and forgot to turn off my parking lights. Found the lights on when I came back to the car after a 2-hour movie. Car still started up just fine
Old 04-15-2017, 01:06 AM
  #96
mfanatic325
Everything still fine. Not a single hiccup. 100% voltage regulator and/or alternator. Hopefully this serves to help anyone else in the future, should you experience the same random overnight power-draw issues as I did.
Old 04-15-2017, 02:28 AM
  #97
mffarrell
mffarrell's Avatar
Glad to hear you got it all sorted out.
Old 04-15-2017, 02:30 AM
  #98
mfanatic325
Old 04-15-2017, 12:06 PM
  #99
Kevinmacd
Kevinmacd's Avatar
The difference between the auto and manual alt is the manual has an rpm override clutch on the pully!
Old 05-02-2017, 10:50 PM
  #100
cwilt
cwilt's Avatar
Update... and much thanks.
I finally got off my butt and ordered the alternator from Rock Auto a couple of weeks ago. A huge thanks to Mfanatic325 for the info and saving me huge $$$. Also a huge thanks to Carlos and Kevin for the info on the clutched pulley.
I installed this yesterday along with a new belt. My voltage meter in the dash used to read around 13.5 when charging, now it reads 14. I barely made it out of the neighborhood on my test drive and it finished charging. Before I would have to drive for about 20 miles before it would be charged.
Much better performance now and peace of mind.
Thanks guys for all the help.
Old 05-03-2017, 11:33 PM
  #101
mfanatic325
Ayyyy, I'm glad I could help save you some money, and all is well with your beloved car. Happy motoring!
Old 01-09-2020, 07:47 AM
  #102
Fabrice Grognuz
Fabrice Grognuz's Avatar
Originally Posted by LexVan
Confirm you connected the drain tube?
excuse me, but what does that mean:connected the drain tube ??
Old 01-09-2020, 10:14 AM
  #103
Carlo_Carrera
If you install a lead-acid "wet" battery in your Porsche there is a small clear plastic tube that should be connect to the vent hole on the battery. It prevents the acid from spilling onto the car and corroding everything.
If you install a dry cell AGM type battery there is no need to connect the vent tube.
Looks like this.
Quick Reply: Random Battery Failure Experience
