Lowering a 996 turbo
Hello all,
I recently purchased a 2003 turbo. I have bought and installed h&r springs on the car this past weekend. Test drove it to make sure all is good and it is.
Next questions is I will need to get an alignment done.
Does everyone usually shoot for the gt2 specs for alignment settings?
Due to the car being lowered, what kind of problems will I have trying to bring the alignment into spec? I have been hearing toe will be off? I know the camber will be slightly negative but I think that can help with the handling. I would however want the toe to be zero or whatever the spec is so I dont get lots of additional tire wear.
What parts should I add before I get the alignment? toe arms? sway bar endlinks? can someone link me or recommend a few brands.
Thanks All!.
Thanks All!.
I am getting ready to do the same mod (H&R lowering springs) and have been reading and researching the parts needed for the job. How was the install for you? Pretty straight forward?
You will most definitely need some adjustable toe links in order to bring the *TOE of the wheels back in true form. Tarett (I just purchased), RSS or if you can source some factory Cup ones would be my first suggestions. Many of the supporting vendors here have their own branded versions which can get spendy. The cheapest ones I could find are the "torque solutions" branded ones. Some people have used them, but I haven't heard much in regards to how well they have held up.
I would also look into purchasing the "locking plate kit" (again Tarett or RSS) which will replace the cam adjusters which apparently come out of alignment.
I believe that is all you will need parts wise. I have also read about people using the GT3 rear sway bars (more adjustment) with the H&R setup.
Of course you can take bigger leaps with your suspension and spend some dough on GT3 Lower control arms...........the list goes on and on.
I am waiting to hear about the alignment specs from some experienced folk here. I believe the GT2 specs help with some irregular rear tire wear.
Hope that helps some
Last edited by 06Turbo; 05-24-2016 at 02:52 PM. Reason: *Toe links clearly adjust the TOE of the wheels not the camber.
The install was very straight forward. I didnt even need a spring compressor or any special tools. Read the DIY on here and lots of people talking about special tools and bla bla.. Didnt need anything other than normal tools.
Toe links will bring camber back into spec? I am not too worried about camber. I am however worried about toe. I have read a few different posts, some suggest 20 million things, other suggest that with the lowering height of the h&r, everything should be back in spec and 1/16" toe in is where it will end up. This much toe in the rear is actually acceptable and helps the car handle better from what I read. The torque solution toe links for rear seem to be about 450, I have a few friends in the industry so I should be able to get those at cost.
The locking plate kits do seem like they would help any movement under hard loads at the track, however I dont track the car.
Send me a PM.
I have an alignment spreadsheet based on ride height measurement as specified by Porsche. Give the numbers to tech, on say a Hunter alignment rig. I get perfect left right tire wear...etc.
i don't have my alignment specs at hand.. but it's a good thing to begin with x73 and/or gt2 alignment and tweak to taste from there. i'm just a smidgen below gt2 height with h&r "sport" ( red ) springs ( on MO30's ) and the torque solutions t-links gt3 sway and yes, toe in will be the issue re tire wear on the inner portion. the ts links will allow you to dial it out a bit to compensate for the "squat" as well as lowered stance especially at wot. it's a good compromise for a street car, that while offering a bit "rougher" ride, more than makes up for that with a more compliant handling car. this done in concert with semi solid mounts and ensuring you have a relatively new t-mount will keep things taut.
OEM GT3 bars? And if so just purchase from the typical OEM vendors. Or is there an equivalent aftermarket unit that is GT3 specific?
Anyone know if the 997.1 or .2 GT3 sway bars are interchangeable with our 996TTs?
I had my alignment recently done on my 2002 by a local well known Porsche shop. This is with the H&R 29385 springs on the car. My biggest limiter with stock adjustment was camber, getting it to about 2 on each side. The rear toe was brought to +10minutes per side (~1/16). Nothing beyond factory components (outside of swaybars which are unrelated to alignment setup).
A street alignment was done for me as that is the cars primary use. So its a boring Front 0 Toe, -1°15' camber - Rear +10°, -2°10' camber
IMO GT2 height too low
This is purely my opinion, but Ifound the GT2 ride height to be too low (for the street). I constantly scraped the front lip pulling into a certain parking garage (every day). Pretty annoying. I had car raised to X73 (I believe) and it was MUCH better. I would caution about going too low. It may look cool but in my case it lowered my enjoyment of driving the car (no pun intended).
I drove the car for about 10 miles as my test drive after lowering on the springs. I dont mind the ride, its not much different than stock. It could also be because my daily is an evo 8 on coilovers.
I noticed the alignment can be brought in close to factory, but its the Squat effecting the alignment and tire wear which is bothering me. I have a heavy right foot.
I also have installed the red springs so on the same boat as you. Funny you mention Tranny and engine mounts.. Just picked up some torque solution ones and I will be installing them in the next week or so.
cheers..
