2001 996 tt won't start
I don't have my Turbo anymore to check if there are any small hoses around the throttle body that can be easily disconnected,but I would say the easiest would be to take the clamp off one of the hoses that connects to the Y pipe. Just take the clamp off and pull the hose off the Y pipe enough to insert the tip of a straw attached to a bottle of starting fluid. Spray a bit and then try to start it. If it starts,you are 100% missing fuel,which I suspect at this point...
Checking the clutch safety switch is a waste of time IMO. If the switch is bad the car won't even attempt to crank because there won't be any power sent to the starter. All you'll hear when trying to crank is " click click " or absolutely nothing.
Pc007, You need to replace your fuel pump. You can measure the amperage draw. But the temperature of the harness connector, shows me that you have an issue. The wiring is the result of the high amperage draw from a seized pump or shorted internal wire.
BTW, this also happens on old auto HVAC blower motors and radiator cooling fans.
Dan
There has been two updated fuel pump from Porsche..
The short can be from the top tank connection, or the harness between the top panel and pump.
If you have not replaced your pump OR if your pump has not been replaced since new.. Replace the pump assy. Again, if you have owner your car for at least 3 years. And have no service records of a pump replacement>>I am recommending that you replace the pump assy. I would also inspect the venture lift pumps and wire support that are inside the fuel cell.
This type of short doesn't happen out of the blue and by itself.
