Clutch replacement
3 hours to do the clutch on a 6TT huh?
Aren't you the guy who was worried about installing a sprintbooster?
https://rennlist.com/forums/996-turb...996-turbo.html
AND posting a "link" isn't that the online equivalent of sticking your di*k (assuming you've got one? ) in a glory hole thru a fence somewhere??
what IS your POINT? clearly you're looking to argue about one thing or another?
obviously that completely depends on how you drive it. if you drive it like i do 5000 is a greta amount. moderate drivers will get more time.
the rebuild kit is less than 1000$ and doesnt require the trans to be dropped otu. simply slide it back and tilt it on a trans jack and pull the p/p and disks out replace them.
I daily the 996TT and I don't have lofty power goals, I want a setup with a powerband for road course events; I like to overbuild just in case things change in the future and the power bug bites. I loved the driving manners of that clutch in my Supra and the feel.. Sounds a lot like it was in my Supra, a great setup for a race car, but I don't think its longevity fits a car that is frequently street driven..
Thanks for your honest review on the product
I drive pretty gentle these days. My Supra was a lot of power, mainly highway pulls (typical Supra stuff lol).. Did a few drag strip events, test and tune days mostly and 1 competitive event. I was really disappointed when it started slipping after a few months considering it was a $5000+ clutch setup.
I agree, the slave elimination is great.. The hydraulic throw-out bearing is a really nice piece. Also for big power goals this would be hands-down the clutch I would select.. If I used my car only occasionally even with lower power levels this would be high on my list. If I only I could make myself stop daily driving my car... Its just too much fun!
I noticed that the price is significantly cheaper than what I paid. Is this a carbon clutch?
I had an OS Giken Triple in my R32 GT-R back in the day and it sucked @ss to drive anywhere but on the track. Plus is was noisy as all get.
How is the driveability? I understand that's a subjective question.
I go back and forth with this. 2.5 Vs Twin. At the end of the day, my car may see ~600whp.
what i found truly interesting was the clutch disk swap itself. since theres no slave it took less than 3 hrs for a complete disk swap. support the trans drop/tilt it so it can slide the mainshaft out and remove the p/p and disks. new parts in slide the trans back in place and BAM! its done. super slick.
Ahhhh.. Now seeing this and going back and reading your first post about the Tilton, I think maybe this is a much different type of Tilton than I used. I had triple carbon disks and the entire setup including the flywheel was under 10 lbs.. sounds like the technology in this Tilton is not quite as exotic and is actually probably much more friendly.
Also just noticed you mention its not in your car.. Maybe this style/design of Tilton is capable of much longer life. Something more for me to look into
Dan
Does the Tilton require a pedal stop? I would imagine it does. Also internal slave will fail and Tilton setups are not made to be daily driven they wear pretty fast in my experience and warp If slipped for to much. We have run them in every daytona prototype, world challenge supra and nissan 370z gs car.
I hate to break it to you, but that style of slave cylinder fails as well. Other car makes have them from the factory. And when (not if) it does fail, you have to remove the transmission to get at it. That's a bunch more labor than replacing the existing 996TT slave cylinder, but I'm sure it is a cheaper part, so it may end up being a similar replacement cost.
Dan
Dan
just one more guy that "overparts" his car lol.
you guys that drag race your porsches deserve whatever you get. this triple ttilton madness is in included in that estimation.
the porsche 996 turbo. the rich man's miata. you guys are just un- fkn believable. sacrilege is what it is LOL.
put oem sachs components in your car and know they were built for it.
How do you know I'm "overparting" my car? I'm not 100% sure what my plans are for this ca,r so how can you? And by some power from beyond you DO know what my plans are, can you tell me so I don't buy parts twice! LOL
At the end of the day, I'm not a drag racer. Does that mean my car won't see the track? No, it probably will a time or two.
I'm not sure if the Sach 2.5 will be strong enough for what my car may end up. So, for nearly the same cost of investment and it sounds like similar diveability, why wouldn't I go with the stronger option?
