GT2 slave cylinder conversion
just picked up an '02 996tt with 50K miles and everything checked out except a small leak in the clutch master cylinder (I read this is typical).
I'm thinking about doing the GT2 conversion but was quoted $2K for parts and labor which seems a bit steep, even for the South Florida market. Is that a fair price for the EVOMS kit installed? Thank you all in advance
Basic Sponsor
Nice looking car!
Depending on their labor rate, it's not a crazy number...could you find it done for less? probably a little...
991.2 GT3 RS Weissach Racing Yellow
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
former 1972 911T white, 1984 911 3.2 Targa black, 993 cab white, 993TT arena red, 993TT silver, 996TT speed yellow, 991.1 GT3 white
www.speedtechexhausts.com
info@speedtechexhausts.com
Testimonials SpeedTech Exhaust Videos facebook
2022 Cayenne White
heres the deal. evoms uses all factory gt2 parts and they add a bracket and a braided hose. if you drill the trans and use factory parts the cost is about 600$ plus labor. this is about a 5 on 10 scale to do. gt2 conversion requires removing the coupler from the power steering pump and replacing the master cylinder in the cabin. this is harder than anything you do on the trans.
fwiw i would replace the m/c and enjoy the car for now. if you need to drop the trans for any reason thats the time to do the mod. at the same time do the 8mm ball bearing mod and drop the weights off the shift links.
Basic Sponsor
BBi Autosport Porsche 996 & 997 Turbo Clutch Slave Cylinder Conversion Upgrade Kit
Rennlist Members,
We released our Porsche GT2 slave cylinder conversion earlier this year. It is a direct OEM replacement that does not require any additional parts. Please check out below and let us know if you have any questions! We are expecting to receive another production in soon.
Always striving for innovation, BBi Autosport is proud to announce our new highly anticipated Clutch Slave Cylinder Conversion Kit for the Porsche 996 and 997 Turbo. After successfully tested on both the streets and tracks for over a year, the Clutch Slave Cylinder Conversion is finally available.
The factory power-assisted clutch system has always been the Achilles heel for the Porsche 997 Turbo. Utilizing the power steering system to help reduce the force needed to depress the clutch pedal, it is a flawed design that delivers a mushy pedal feel with poor feedback, and is highly prone to failure. Our system addresses both of those issues by eliminating the problematic factory power-assist system for improved reliability and pedal feedback. Unlike other kits, our system is designed be used with OEM clutch master cylinder, hose, and spring pack. This eliminates the need for additional parts, making our kit a complete plug and play solution.
The other kits on the market simply adapts factory 996 GT2 parts with aftermarket brackets and caps off the power steering pump with plugs. Our kit is our very own proprietary design and does not plug the power steering pump because the plugs can fail. Instead, the power steering fluid is routed through the unit to simulate the factory system. With the failure of the factory system inevitable, this is a must upgrade for the 996 and 997 Turbo to achieve the excellent pedal feedback and reliability similar to that of the Porsche 997 GT2 and GT3 without compromising drivability.
Features
About BBi Autosport
Based in Southern California, we are a Porsche tuner and parts manufacturer. BBi Autosport was founded in the summer of 2005 with the mission of bringing artistry and craft to the Porsche tuning industry. We are committed to producing proven performance upgrades that are manufactured to the highest quality standards. With our new bigger facility, new staff and new product catalog this year, we are a one-stop shop and excited to offer everything from race car builds to scheduled factory maintenance.
With over 30 years of combined motorsport history, BBi’s operation is truly unique. Racing traditions run deep here at BBi Autosport. As the company's founder and technical director, Betim Berisha has worked in Racing for many years at prestigious events like the 24 Hours of Lemans and 24 Hours of Daytona. First for Fordhal Motorsport working on their GT3RS and Saleen S7 in ALMS and Grand Am series, Alex Job Racing on their ALMS GT3RSR, J3 Racing working on their GT3RSR and then Porsche Motorsports North America as their dyno tech an supporting Porsche teams at ALMS, Grand Am, Speed World Challenge events. Sharing the same passions, most of BBi's support and shop staff have also previously worked for other motorsport programs. Being a one-stop shop, BBi Autosport is equipped to offer everything from hand-built hard goods to championship-winning GT3 Cup Cars.
For up to date information of current shop activities, projects, and product releases, please follow us on our Facebook and Instagram accounts:
https://www.instagram.com/bbiautosport
https://www.facebook.com/BBIAutosport
Features
- Eliminates the problematic OEM power-assisted clutch slave cylinder for improved reliability
- Significantly improves the clutch feel and engagement
- Designed to be slightly softer than the factory 996 GT2 conversion kit for excellent drivability
- Proprietary plug and play design
- Retains clutch master cylinder, hose, and spring pack
- Requires less installation time than other slave cylinder conversion kits
- Does not adversely affect clutch life
- Precision CNC machined and hard anodized aluminum construction
- Hard anodized 7075 aluminum piston
- Designed for Porsche 996 and 997 Turbo
About BBi Autosport
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
What does the BBi mod do to clutch pedal effort?
Basic Sponsor
BBi Autosport Porsche 996 997 Turbo Slave Cylinder Conversion
CincyScott,
Designed to be slightly softer than GT2 version, our lead technician - who have driven many of these cars of the years - reported that the pedal feel is very close. This conversion kit is installed on one of our flagship project cars (shown below) here at BBi Autosport and we received positive feedback from the client after taking delivery. They are currently on back-order and we will try to get our clients and dealers to post up reviews soon.
BBi Autosport "Project Swan" 997.1 Turbo (GT2 Conversion)
- Jerry@BBiAutosport.com
Yep, I will definitely goes with these when mine needs to be replaced...again.
