Lightest exhaust without pressuredrops?
Hi
I wonder which exhaust/brand/design after the turbos that might be the closest to fulfill the following:
* Low mass...!
* The least pressuredrops, i.e. probably large pipe diameters and generous bend/s with large radius...?
* Reasonable dampening
* Not necessarily stainless steel, nor Ti
/Slalom996T
* Low mass...!
/Slalom996T
Hi
* Low mass...!
/Slalom996T
* Low mass...!
/Slalom996T
* The system need to survive reasonable hours without triggering the CEL since it will be streetdriven as well
Regarding straight pipes (L & R branch separated , i.e. non X) after the turbo's: are there any format with any dampening features available on the market?
Regarding pressuredrop: Any available evaluation of the pressurdrop/s via simulating the exhaust flow up to x k rpm?
What is the largest diameter "100 cell" cat available in a 996 exhaust system?
Slalom996T
Do you do any research?
probably Kline...
Bam!
X-pipe in Ti with anti-drone helmholtz resonators. Swap out the HFC's and throw on some straight pipe sections for better flow. I've got a similar setup in 304 SS and it's around 25-30 lbs with muffler sections rather than cat sections. 321 SS or Ti would have been much lighter but that' obviously more $$$.
Preliminary version:
996T Exhaust market with large pipe dia and cat's with low cpsi spec's, in falling order
Oem: 60mm Od, 300cpsi cat, 0.36 dPBar, 26kg
76mm Od, 100 cpsi cat
SpeedTech, 13.2kg
911Tuning X sport, 12.7kg
911Tuning X race, 10kg (?)
76mm Od, unknown cat spec
USP
AR Design, 18,2kg
76mm Od, 200 cpsi cat
GMG WC-GT, 16.8kg
BBi Barcode
EB Werks, 76mm (?) Od, 8.9kg
70mm id, 100 cpsi cat
FVD, 18.5kg
Remus, -57%Bar dP, 20kg
70mm Od, 100 cpsi cat
Europipe, 130mm cat Od, 0.18Bar dP, 24kg
Milltek, 24.5kg
70mm Od, 200 cpsi cat
Fabspeed Maxflo, "-11.4kg"
Fabspeed Supersport
63mm Od, 100 cpsi cat
Kline, 108-127mm cat Od, 0.18Bar dP, 13kg (?)
Corrections, added specifications (especially concerning pressuredrop) and/or added exhaust models are welcome!
Are there any large diameter straight pipes with 100 cpsi cat's and any sort of dampening features available?
Slalom996T
SpeedTech, 13.2kg
USP
AR Design, 18,2kg
GMG WC-GT, 16.8kg
BBi Barcode
FVD, 18.5kg
Milltek, 24.5kg
Fabspeed Supersport
Slalom996T
With all do respect( said like Rickey Bobby) it seems like a lot a fuss to go crush some cones I would drive the "Slalom TT" stock for a bit a and learn to drive it before you go out to beat Danny Popp. Just go drive the car and have fun. I would dare to say that the 996tt is a very capable car, seat Time is more a value at first then any mod you have talked about, just my 2 cents. From your posts you have spent over 40k easy and that would buy a lot of track or Slalom time
Basic Sponsor
Hi
* Low mass...!
/Slalom996T
* Low mass...!
/Slalom996T
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
John@Fabspeed.com
215-618-9796
www.Fabspeed.com
It would be nice if you could supply the individual pressuredrops of the noted products of yours, assuming the're correcty noted?
Might you have a 76mm straight pipe (well, at least somewhat nicely curved) with CEL safe 100 cpsi cats with some means of a dampening feature planning to be marketed?
Slalom996T
