What did you do to your 996TT today?
#811
Started redoing my driveways as my car is now so much lower it will scrape quite a bit on any entry and exit... BTW Tim left the Ohlins set up on the highest possible yet correctly weighted settings and alignment so I would hate TO SEE it and my driveway FIGHT if it was on the lowest settings
-V
#817
put down second coat of epoxy on the garage floor
Installer for Mohawk lifts comes tomorrow to test drill the floor to ensure it will support a lift. If the floor passes I will have a lift soon
I have 10.5 ft ceilings in the garage which limits my choices. I also am becoming rather militant about buying American made products (except for cars ). I was down to Rotary and Mohawk, but the American made Rotary product won't fit, so my choice was made for me. Kind of excited.
#818
No. It was hot. The temps today were pushing 90F. When it's a bit cooler, this is going to be a very very fast set up. I was about 2 sec off my personal best. We are doing time trials tomorrow.. Here is a picture of the car just coming out of a turn pulling right at 1.3Gs. You can see that even with 1400/1500 rates there is plenty of lean under load. After 2 full track days I truly think that 1700/1800 will ultimately be the optimum no holds barred set up..
Rturbo by pwdrhound1, on Flickr
On a sad note, he was diagnosed with colon cancer just 2 months back and died shortly after surgery on Monday night.
Just turned 50. Life is short guys.
#819
I had my nose off for cleaning just a couple of weeks ago and I was all set to install mesh and then decided not too. I have been using a long cardboard tube on the end of a vacuum to suck out the radiators from time to time and it worked better than I thought so I am leaving the mesh off and will continue to vacuum.
#823
