996 Turbo Forum 1999-2005
For the Non Believers
Old 04-20-2011, 08:39 AM
T2
T2's Avatar
Default For the Non Believers
2003 996 Turbo X50 - Stock
Old 04-20-2011, 08:41 AM
DAVISRILEY
DAVISRILEY's Avatar
I can testify to this. Nicely done tom, what's the cayenne at now? You really should come out to Indiana for a de sometime.
Old 04-20-2011, 08:47 AM
MechanicalEng
MechanicalEng's Avatar
Old 04-20-2011, 08:57 AM
Chaos
Chaos's Avatar
You da man !
Old 04-20-2011, 09:14 AM
LVDell
LVDell's Avatar
Now THAT is car that is driven and loved. Nicely done. Here's to another 300K
Old 04-20-2011, 09:52 AM
JG 996T
JG 996T's Avatar
NICE - 252K more to go and I'll be there too.
Old 04-20-2011, 10:52 AM
Land Jet
Land Jet's Avatar
I feel like a toddler with only 26,000. Best of luck for many more happy miles.
Old 04-20-2011, 10:59 AM
jpflip
jpflip's Avatar
What a great way to start the day and see something so promising! Thanks for sharing....
Old 04-20-2011, 11:05 AM
Kevinmacd
Kevinmacd's Avatar
Nice to know there is a possibility we all can achieve that! Thanks!
Pierre
Pierre's Avatar
T2, I hate you! Mine has only 372'700 km (231'000 miles). And isn't exactly stock...
Seriously, congrats!
Old 04-20-2011, 11:16 AM
RxPorsche
RxPorsche's Avatar
That is so awesome . Thanks for sharing.
Old 04-20-2011, 11:54 AM
Tim Wasmer
Tim Wasmer's Avatar
Holy Cow!
It would be interesting to hear what you have replaced etc. in 300k
Old 04-20-2011, 12:24 PM
SSST
SSST's Avatar
I believe!
Old 04-20-2011, 12:26 PM
T2
T2's Avatar
Here is a list I have compiled over the years for the repair work:
• All three front radiators (right front now twice)
• water pump
• coolant expansion tank (as a precaution with water pump)
• power steering pump/reservoir (for the annoying squeal)
• right front bearing, left rear bearing
• front diff (due to front bearing issue)
• clutch accumulator and slave cylinder (4 times now for the slave - one time lasted only 4 days and it failed - PCNA pulled all the parts on the shelves in the US as a result of this and a few others in the country with a similar issue)
• wiring harness repair (passenger side front most cylinder – harness to the coil pack chaffing issue)
• rear main seal (while engine was down for a wiring harness repair we pulled the tranny to inspect the bearings, clutch, pressure plate and flywheel)
• two bearings in the clutch assembly – one was bad, one was fine
• Decarbon the secondary air ports from the intakes to the exhaust
• Gas cap – the gasket finally went at 186,000+ miles
• Check valve and carbon canister on the vapor recovery system for the fuel tank
• normal services done on time
• brake pads (only on the 4th rear set and 5th front set - car has PCCB's and is tracked 6-10 days/year)
• oil changes every 5000 miles religiously – Mobil 1 0W-40
• tranny and diff fluids every 60,000 miles
• Baileys DV's
• GT-3 Cup front brake ducts
• Idler pulleys
• Belt (done a couple of times)
• Suspension will be replaced shortly (KW Clubsport)
• Carden shaft will be replaced (second time now) when the suspension is done
• All four half shafts will be replaced with the suspension
• Motorsport Sways and Tarett drops links will be replaced with the suspension
• Protomotive intercoolers going in when suspension is done
• Two rear heat shields will be replaced when the suspension is done
The car is on the original turbo's, original clutch and original engine still.
T2 continues to knock on wood....................
Old 04-20-2011, 12:49 PM
jpflip
jpflip's Avatar
T2 did I read somewhere that you are from New England and you are driving your car in winter? Salt, slush, rain + you are tracking your car! Amazing, may be that is one of the aspect of this kind of car it should not be a garage queen, but driven daily!
Quick Reply: For the Non Believers
