Flashing Check Engine and Pressure Gauge Bouncing
Hey guys,
Driving last night and got a "Drive to Workshop" message and (an intermittent) flashing check engine light (I can't say it was continuously flashing, more like coming on and then off). I know the flashing one generally means you should stop the car because it might be catastrophic or the catalytic converter is being harmed. However, when I checked the instrument cluster I noticed that the oil pressure gauge was all over the place. It would hold steady at 3 bar, then bounce up to 5, then down again. If I accelerated it would go to 4, or 5. The check engine light would go off if the oil pressure came up.
So, I continued driving to my destination thinking the oil-pressure sender unit was bad (again). When I got there, I checked the oil level and it was where I expected it to be. I used to get "Check oil pressure" messages where the gauge on the cluster would flatline while I was driving, and then come back up to what it should be. I replaced it and it has been fine for a year.
I guess I could check the wiring to make sure nothing popped off first. And I will pull the code when I get home with my Durametric. But, I think I can continue to drive the car as it seems to perform the same. What do you think? Anyone had this type of behavior?
My only concern is that every reference to the oil pressure sender failing refers to "Check Pressure" message and the gauge briefly flat-lining before coming back up. Mine has a CEL (briefly flash, turn off) and "Drive to workshop." Hoping to get verification that someone else has had the gauge bounce around. I'll check the wiring today.
I have to admit that when I had problem with the sender I only had the "check pressure message" . No cel but the ECU pick it up because when I connect Durametric and went into the "Cluster fault" it tells me that I had a fault with oil pressure.... But again no "drive to workshop"
Green wires appear to be affixed tightly to the sender, with nuts on top of them. Hopefully will be able to drive home fine (I really think so) and then check codes. Can't really check the wires on the bottom.
(Also, if the engine running a bit rough a marginal connection in the oil pressure sender wiring could have been flopping about and this can account for the bouncing oil pressure reading.)
Chances are if there was a real oil pressure problem you'd have evidence of it now cause the engine would be manifesting the symptoms an engine with oil pressure issues manifests.
Just to be save though, you might consider verifying the oil pressure is ok.
Read the error codes and post what they are.
Sicnerely,
Macster.
Yeah, today I drove the car a tiny bit. The CEL went off on start. Car seemed okay. After a bit of driving I felt a slight hesitation like a misfire and the CEL came back, flashed a bit, then stayed steady.
I remembered fueling and only clicking the cap twice, so I reseated the cap. Did a few pulls in 2nd and 3rd and all seemed okay, but then I felt another misfire. Bleh. I'll limp the car home tomorrow and pull the codes.
There is a GIAC flash, the only "mod," which I could reflash back to a stock-like program.
I changed plugs and coil packs myself at 60,000 in December of 2009. I have 69,000 on the odo now. Never a problem until today, so I think that job went fine.
