Feedback on 996 with relatively high mileage
Hello Everyone,
I'm a long time lurker, now member.
I've always liked the 996 and feel that it represents a good value in terms of looks, performance and pedigree.
I am curious to see if any current 996 owners/experts would be able to provide me with any feedback on a local car (to me at least)?
Here is the link: 996 MK1 2001
The car has some cosmetic issues. Among them a cracked/scratched front bumper, some wear on shift ****, missing/destroyed cup holders, curbed wheels and is in need of a paint restoration/buff. I called LN engineering and they have no record of the IMS having been replaced. It's a 1 owner car with some service history. Since I'm not a mechanic I am looking to have PPI done.
My goal is to use it as a daily commuter and maintain it until it completely falls apart. If I could get 20k miles out of it I would be happy.
If anyone could provide me with their initial thoughts I would be most grateful.
Thank you and have a lovely day,
Bringebaer
Bringebaer
Thank you for your reply. Yes, it seems you can get a pretty pristine example for 18-20k, but living in the city I would just hate to come back to my car dinged/scratched up. This one is a bit scruffy so I wouldn't feel so bad (if that makes sense). It also has some desirable options like the painted center console and what I believe are the sports seats (I don't like the ruffled leather seats).
My impression from reading a lot of threads is that one possible factor to the IMS bearing going bad could be a lack of use resulting in the lubrication inside the bearing going rancid (you all know much more about this than me).
My research shows that the retail price is roughly in line with KBB/Edmunds values, but that the selling price of similar cars from a retailer should be in the 11-13k range (which is what I would aim for).
Thank you again.
Thank you again.
Seems a fair price for a fair car that needs a little TLC. But, it's a tiptronic so it's not as desirable for most who are into these cars.
As a 2001 model, it most likely has the single row bearing... but at that mileage if it hasn't already been an issue, one has to wonder if it ever will be???
Still, there are two cars in my area that are manual tranny, with under 100k miles available for less. And one even has had IMS, RMS, clutch and mounts swapped already.
IMHO, that's a $13k car all day long. You can do better.
Couple notes about the car: its listed as an auto but its a 6 speed (which is a worth more) but makes me wonder what else is incorrect about the listing. Tires look to be in good shape, it has a painted center console which is a plus. It looks like exhaust is sagging which could (probably/definitely) means you need to replace the rear engine mounts, but thats a relatively easy DIY job that will cost between $120-350 in parts depending on if you go aftermarket or genuine Porsche.
Some notes in general. There are a few things I've read on the forums that ring true: 1. "There is nothing more expensive than a cheap Porsche" and 2. "Cars are machines designed to fail". Eventually everything wears out and breaks - it comes down to where on that curve you buy the car. High mileage cars aren't necessarily bad. For example, you may be buying a higher mileage Porsche that has recently had the clutch, RMS, etc replaced. In that case, its a better deal than one that has those original parts and will need to have them replaced almost immediately after you buy it. So, I guess what I'm trying to articulate is that a higher mileage, well maintained car can be a better deal than a lower mileage well maintained car if its just been gone through and some key wear parts have been replaced... and its definitely a better deal than a low mileage neglected car.
Thank you all for the quick and very helpful replies. Especially your notes about the sagging exhaust (it has the x54 stainless tips options according to the option sticker). The option sticker also notes the interior as "AD" which according to my research should indicate a black interior. However, Porsche NA also confirmed that the build spec had a grey interior. Coupled with the 249 code (which could be z49, hard to tell) makes me wonder. Regardless, not a big deal to me as long as it is not related to the soundness of the mechanicals.
For the benefit of others, what tipped you off on the exhaust tips/bad engine mounts
? The distance from the bumper cut out to the exhaust tips?
Charlieaf92:
That was my thought process as well. High mileage, but maintained. Hopefully some of the more expensive wear and tear items have been covered (see attached carfax with service history) so I can have a relatively smooth ride for a year or so until the rug is inevitably swept from underneath my feet. The next service interval is in the 140k range from what I've read up on.
Will a leakdown/compression test be able to indicate impending d-chunk, ovaling or AOS issues?
CARFAX Report
Thank you very much once again!
Charlieaf92:
CARFAX Report
What is it specifically about that car that interests you?
'01, 115k miles, $15k
https://sfbay.craigslist.org/sby/cto/6044288613.html
'99, 140k miles, $13k (IMS/clutch done)
https://sfbay.craigslist.org/sby/cto/6021287668.html
etc... These are not rare cars.
VitaminC,
This car is in the City, so it is easier for me to go look at it. It is also at a dealership which makes things a bit cleaner with regards to settlement etc.
In addition, it has the litronics headlights (makes a huge difference in my personal opinion). Also, there aren't any apparent modifications (wheels, stereo etc) that I would have to remedy.
Cheers
Charlie
Hello Everyone,
Bringebaer
Bringebaer
See link:
http://www.getauto.com/2001/porsche/...ails_161926347
Date of listing is given at bottom of vehicle details block.
Wow, all great advice.
Live and learn as they say.
Macster, good point. It was however listed for $17,999 and even more for the longest time. I believe that might help explain why it has been sitting for so long. As a result it fell in a weird bracket of cars with much lower mileage and that were in better cosmetic condition.
Looks to me as a reasonable car! Make sure you got 3k$ left for some additional repairs if necessary. Some repairs were done last year but probably it would need a good maintenance done. If you can have a good PPI done you will have a reasonable idea what you are getting into. Then go and drive & enjoy. Don't worry about IMS, RMS, sagging exhausts (who cares!) and all that stuff. This is not a pristine car, it is not what you are looking for and it would be a waste of money if you try to get close to that.
Just my 2c.
Just my 2c.
Have you seen it in person and/or driven it yet? If possible, you should drive a few different 996's so you can get a feel for them.
That's potentially a lot of money for 20k miles of use.
