What else while doing IMS?
In a month, I'm taking my new-to-me 02 C4S out of storage, to get the IMS Solution installed.
What else should I have looked at or preventatively replaced?
Im sorry, I don't have the time, between work and two little kids, to read through all the threads.
RMS? AOS? Coolant Tank?
Thanks!
-Geoff
Thanks!
-Geoff
Good luck!
Thanks everyone.
Sounds like I should talk to the shop about RMS, AOS, clutch/flywheel inspection. All the standard stuff I had considered already. Things I didn't think of were water pump and thermostat.
I had a magnetic drain plug installed prior to delivery as they changed the oil before I picked it up.
The car only has 27k miles on it. I'll discuss with the tech, but do you guys think that would reduce chances of needing to replace water pump and thermostat? Are there revisions of the part that should be upgraded to, or are they just wear items that are replaced with the exact same part?
