996 Forum 1999-2005
Oil filter for use with LN spin on adapter in U.K.
Old 02-04-2017, 03:39 PM
Noz1974
Noz1974's Avatar
Default Oil filter for use with LN spin on adapter in U.K.
Hi guys
Another question, what's the best spin on filter to use with the LN adapter here in the U.K.
Napa gold not available here, is there a K&N filter available with the same properties, they are known to be good filters here in the U.K.
Old 02-04-2017, 04:05 PM
wyovino
wyovino's Avatar
Here are the identifiers used in the US:
K&N Gold HP-1007
Mobil1 M1107
Hand tighten, plus 3/4 to 1 turn.
Old 02-04-2017, 04:07 PM
wildbilly32
wildbilly32's Avatar
Bosch 3332 per Pelican Parts
Old 03-27-2017, 03:05 PM
jandackson
jandackson's Avatar
I just paid $8.62 for the Napa 1042 at my local Napa.
Old 03-27-2017, 03:24 PM
DBJoe996
DBJoe996's Avatar
Received 1,093 Likes on 703 Posts
My LN oil filter adapter "kit" came with a K&N filter HP-1007, so I think you would be good with that.
Old 10-01-2017, 06:16 PM
Jnelso
Jnelso's Avatar
I installed the LN oil filter adapter awhile ago on my 1999 C2 and using the Napa Gold oil filter, the first one had some oil seepage, so I just installed another one and that is leaking also. I torqued both the adapter and the oil filter according to recomended specs. Anyone else having leakage on theirs, or anyone recomend a different filter?
Old 10-01-2017, 08:34 PM
jhbrennan
jhbrennan's Avatar
Where is the seepage coming from - the adaptor or the filter? Filter should be installed by hand then once snug, turned another 3/4 to 1 turn to finish filter installation. I've never had any leakage using hand tightening.
Old 10-01-2017, 08:42 PM
Jnelso
Jnelso's Avatar
Just what I did. I think I will have to monitor the leak more closely to be sure its not from the adapter.
Old 10-01-2017, 08:51 PM
KoB
KoB's Avatar
If Wix filters are available in the UK, the Wix 51042 is the same filter as the recommended Napa Gold filter.
Old 10-02-2017, 07:58 AM
Noz1974
Noz1974's Avatar
The K&N hp1007 seems to work great on mine, if you have oil seepage , did you lightly oil the seal on the filter adapter before you installed it, if not it may have dragged as you tightened up the filter adapter pulling out of position allowing oil past, pull the adapter to check, it's easy done!
Old 10-02-2017, 09:39 AM
Silk
Silk's Avatar
Here also k&n 1007 and no problems. Will switch to the washable filter next week.
Old 10-03-2017, 10:39 PM
dan_189
dan_189's Avatar
The first K&N I bought was made in the USA, second was made in Mexico and i've read a fair few complaints about the quality change.
@OP i'm in the same boat, Nappa not available but WIX filters are (they are the same) WIX is the manufacturer for Nappa.
Quick Reply: Oil filter for use with LN spin on adapter in U.K.
