The digging out from my money shift begins.
#46
It is notable that although fools commented about D-Chunck, casting defects could not really be the primary cause. We will gently avoid mentioning the real cause in respect of the sensitivities of the OP.
But D-Chunk may be a good fig leaf to conceal the embarrassment.
The real cause - a mistaken 4th to 1st change instead of 4th tho 5th or 3rd?
Could the cause of this engine detonation be a worn shifter - too much play in the bushings?
Another fig leaf and a hint to others (&me!)with floppy shifters?
The motor that was in this car is proof that they can be good even with high miles. Of course this car was very well maintained (thanks Gator) with a ton of service history, lots of quality oil changes, and lots of driving.
I have no doubt that if I did not make the mistake I made, the car would still be on the road with its original motor, and I would have made it through all of that last weekend at Summit Point, instead of blowing the motor 12 minutes in to the first session.
Now to get the new motor in so I don't miss the first event of the season back at Summit Point on the Shenandoah Track 4/7-4/9.
#47
So, is the shifter in the car with the dead engine a bit sloppy ?
I ask because of the comments about the GT3 shifter upgrade being 'like a rifle bolt' .
Without any slop in the GT3 shifter bushings, it seems less likely that this expensive mistake would occur. Just thinking about preserving your next engine for more than 117k miles ! Maybe a new shifter makes sense also ?
#48
#49
OP, is that the normal money shift? I've had two, and it was going from 6 to 2 instead of 6 to 4 - wasn't track driving, just trying to get some quick power for a pass on the highway. I don't know much, but it sounds like the shifter is really sloppy if it happened during a straight shift.
#50
Shameful Thread Killer
Lol, you're not gently avoiding anything if you're going to spell it out anyway. Anyways, the OP did title the post "digging out from my money shift".
#52
Not sure the is a normal money shift, it was a stupid one. I had just given a point by as I started to brake, so I was quickly getting my left hand back to the wheel and moved my right hand over to make the shift. I don't really recall if I just mis-shifted or thought the car was slowed down more that it was. I really did not think much of it since the damage was not immediate, it made it two laps before it let go.
I did a money shift at the track. Was short shifting from 2nd to third on a slight rh turn and the g forces were pushing my hand to left and I hit 1st. Luckily I was able to put the clutch in immediately and I didn't even get an over rev on the counter.
#53
More progress. Donor motor is in the car! Once I got it mounted, I decided to call it a day, and I need to wait for some parts to come in to finish plumping and hooking everything back in.
Some potentially good news, discovered that the donor motor is a remanufactured from Porsche with the 997 IMS. I ultimately decided not to crack the case at this point. I did replace clutch assembly, AOS, water pump, thermostat, plugs, and a few other things.
New hoses will also be installed. If all goes well, it will be running again on Sunday.
#55
It could also be called:
"The Wife Wants To Kill Me Shift"
"The Wife Wants Her Garage Spot Back Shift"
"The Why Are My Friends Laughing And Pointing At Me Shift"
"The Wow Even When You Think You Are Done Spending Money, You Still Have $300 Worth of Coolant And Oil To Buy Shift"
But, I find Money Shifts sums up all of the above pretty well.
#58
#59
An Update! It's RUNNING!
A couple small issues to deal with. I don't think the throttle cable is routed correctly, so at start up, it is revving high.
I need to bleed the clutch since I needed to remove the slave, currently the pedal is stuck to the floor, but I need to flush the system before the first event so no big deal there.
I'll be creating a new thread detailing the differences of swapping a 2000-2002 3.4 Engine into a 1999 car since there are a few things that are different.
