996 Forum 1999-2005
Fault code O2 Sensor
Old 02-08-2016, 07:43 AM
Dr. Wood
7th Gear
Dr. Wood's Avatar
Default Fault code O2 Sensor
2005 TT S Cab... Check engine light on, fault code said O2 Sensor bank 2.. Which one is this and what part number do I need..
Thanks..
Old 02-08-2016, 09:53 AM
DBJoe996
DBJoe996's Avatar
Received 1,091 Likes on 701 Posts
There are two O2 sensors pre and post cat. I think this diagram may be correct for your car (997) and it shows the two sensors 30 and 31 with part numbers http://www.autoatlanta.com/porsche-p...section=202-01
Old 02-08-2016, 11:08 AM
Ahsai
Ahsai's Avatar
Try this one too
http://www.autoatlanta.com/porsche-parts/hardparts.php?dir=997T-07-09&section=202-00
Old 02-08-2016, 11:31 AM
Macster
Macster's Avatar
It is best to post the error code(s). This way one can consult the references to know which bank and which sensor on which bank is being indicated.
Old 02-08-2016, 10:34 PM
Dr. Wood
7th Gear
Dr. Wood's Avatar
Cleared the code.. Will,run again.. Also it is a 996 2005 TT S
Old 02-08-2016, 10:58 PM
Macster
Macster's Avatar
Ok. I have the 996 OBD2 reference. (I grabbed one for use with my 2003 996 Turbo.)
Old 02-09-2016, 03:24 PM
kpl
kpl's Avatar
if it comes back, swap the sensors side to side one pair at a time, to see if the code switches to the other side (probably a bad sensor), or stays on the same side (probably a bad cat).
Old 02-09-2016, 03:40 PM
RngTrtl
RngTrtl's Avatar
also, you can get a wireless (bluetooth or wifi) adaptor and use Torque (or the equivalent) to graph the gauges and monitor them. It should be pretty easy to tell which one is the culprit or if you indeed have a cat going bad.
Old 02-09-2016, 06:53 PM
Dr. Wood
7th Gear
Dr. Wood's Avatar
Have the durametric and will drive it till code reappears.
Quick Reply: Fault code O2 Sensor
