Tire pressure?
I'm not saying that is good or bad. Its just physics
People often mistake factory recommended tire pressures and don't realize those settings are for a full load.
Lower them down to whatever suits your driving preferences and setup. There is no wrong or right. For example, I'm found 34f/38r to be best for my GT3 CO setup.
Alpi, honestly, I've been thinking about lowering the pressure a bit. LA streets are rough, so the current set-up is a bit bouncy. But I'd hate for lower pressure to damage the wheel..... because the streets are ****. Also, with the current set-up, I'm noticing more wear in the center of the tire vs. the margins.
I get a lot more mechanical grip having lowered the rear, especially around mid-corner bumps which cars tend to encounter more often on the streets.
If you stay above 35, you should be ok. I've seen my fair share of potholes living in Chicago and haven't had any issues.
