New affordable 996 engines from porsche?
I found this recent thread on 911uk. It looks like porsche is offering new m96 long blocks for 2,800 pounds. About $4,100.
Does anyone know if these are avail in the US? Discussion there notes Porsche doing this as the 996 now considered classic by them. And of course discussing if porsche made any upgrades to address known weak areas.
http://www.911uk.com/viewtopic.php?t=101085
even at $4100 for the short block, isn't that what is usually damaged when the IMS fails? If that is the case, would that lower core charges?
Forgive me does long block mean the same thing in "Porshe" terms as it does in American engine (IE cam cover to oil pan)
and short block would be rotating assembly and block.
I have not read the thread the OP posted (but plan to)
The Cliff Notes
"Slight problem is the engine code is M96.03" only
"since they not only contain all the old potential problems of bore scoring and ovality, coolant flow restrictions and ”D” chunking etc "
"but far better to strip, inspect and assess the old engine first "
"When it comes to re-sale prices I also think that engines fitted with Alloy Nikasil cylinders will hold a premium and that after a couple of years use those with Lokasil cylinders will still embody a risk that may put some buyers off."
Beware cheap IMSB:
"Also this week we have an engine in failed and damaged due to the complete failure of an expensive IMS bearing conversion originating in the USA and promoted by others over here."
Beware cheap IMSB:
Again, I have not read the original thread - but could you talk more about this? Which replacement solution failed?
Perhaps.
But what about Lokasil vs Nikasil. Perhaps Porsche is just selling off old stock before the demand declines ? For that money why not get the permanent fix - Nickies? The resale value of a rebuild with Lokasil vs Nickies is a litmus test. Certaily the Lokasil from Porsche may appeal to the cost minimizing /flipping approach.
I am rebuilding an M96 now. This Porsche 'new deal' would have been unhelpful financially unless I had severe ovality+taper+scoring.Fortunately I did not.
I e-mailed my mechanic to inquire about these engines. My car is about to get an engine rebuild anyway and it doesn't hurt to ask before it gets dropped off. I'll post his response when he gets back to me.
great, yet another inherent flaw in these engines.....
and the alusil/nikasil etc - straight out of the e34 V8s...
i didnt read every word, but it seems that company believes the block issues are as important as the RMS..
http://www.hartech.org/porsche_996_9...ance_plan.html
If the engines were so bad you would think no one would "insure" them.
