Convertible top hydraulic leak
So my top wouldn't open this morning. So looking under the cover I find the hydraulic reservoir empty, not a good sign, when I closed it last night the pump sounded like it was running empty so i expected something.
So I walk around the vehicle and find a oil stain in front of the right rear wheel and oil on the wheel arch liner (first pic)
The second pic is looking down the large cylinder on the right side it appears the hydraulic line / connector is leaking at the front end of the cylinder
any body changed one of these?
I have a 99 with the same problem,both mine are leaking,i posted a few days ago for info but got no replies,i was thinking of changing them myself but looks like they are hard to get at and there is a lot going on in there,the dealer will kill you on the price on these
I know about that company to have them rebuilt its $400 for the pair,the problem is doing the job,it looks like they are hard to get at,and everything has to be put back together right or there are a lot of thing to go wrong
I have a call into the dealer for a quote on replacing it, so we will see.
The cheapest replacement new part I can find is a little over $700. It looks do able from the back but not easy. I haven't looked at whats involved in taking off the interior trim this would get a lot more access.
There's a couple of places doing rebuilds, but I don't want the car off the road waiting for the re
I'll post with the dealer price and let you know what happens.
the guy in FL will take a core deposit then refund when you send him the old ones that way you don't have to tie the car up,his rebuilds are surpose to be better than factory and are $400 for the pair,let me know what the dealer says im curious
Albert
Albert
I had this same problem last year. Used Cabriolet Hydraulics in FL. Cost for the kit to replace both cylinders, new seals and fluid was $600 with a $200 core credit. Downloaded the manual to replace them, but at the last minute decided to have my indie to it. I think he charged $200 for both cylinders.
Thanks for the Link LordVicious.
So I got the quote back from the dealer $1,264 roughly $850 parts including fluid.
I find some one for rebuild who will core exchange just one cylinder, There is very little labor (15min may be) saved by replacing both at the same time and its a hydraulic cylinder, its the fitting that's leaking not the rod seal so there so speaking as a engineer there is really no reason to change both at the same time. May be I'm in a pissy mood but for the company to Highly Recommend changing both is just a annoying sales pitch and makes make not want to use them
1999 996 convertible top hydraulic leak
Have a '99 911 cabrio, is leaking both sides, ore on the left side (driver). I'm afraid it would cost a fortune to fix. I took this car as a payment and wondering if this was the worst decision ever.
The motor seems to work, the top starts going down but does not complete the movement.
I took it this morning to a Porsche shop (not dealer) and just got the Est, it's 749.00 parts + 745 labor, total 1,664.75
I don't have a leak, yet, but since my cab is 21 years old I bookmarked a kit in anticipation. If you are handy, or know someone, check this one out:
https://www.ebay.com/itm/Hydraulic-C...m/273328486330
I think this is one of those jobs that seem scary but might actually be easy (and definitely not one for the dealer).
Can you share the name of the company in FL that rebuild the hydraulic cylinders?
Cylinder replacement
M
