ODBII & Iphone Software to make track day videos
Hey everyone,
I just bought a WiFi ODBII scanner for $23:
http://www.amazon.com/exec/obidos/AS...im&tag=fged-20
And I'd like to make videos that look like ALapRecord (Android only) on my iPhone:
https://play.google.com/store/apps/d...corderhd&hl=en
The best software I could find for iphone was DashCommand $50:
https://itunes.apple.com/us/app/dash...ign-mpt=uo%3D4
Have any other recommendations?
Harry's Lap Timer is excellent...
Three different feature levels as described here, $10 (Rookie), $20 (Petrolhead), $28 (Grand Prix).
The Petrolhead version is probably the one you need unless you want multiple camera angles (you can slave a second IOS device or Hero camera for secondary recording on the Grand Prix).
Video's like this are very easy to generate, also will overlay OBD data if you configure it correctly. You can also configure external, high resolution GPS units for a higher level of accuracy, but I've found the camera and GPS built in to the iphone provide excellent results for track days.
...Combine it with a RAM Mounts iPhone windshield suction mount (less than $40 from expressmounts), and you are ready to go!
I hope so, bought it off of the recommendation in this thread:
https://rennlist.com/forums/993-foru...or-iphone.html
If you jailbreak your iDevice, you can usually get the cheapo bluetooth OBD devices to connect.
You can do it with a Bluetooth OBD dongle. I'm currently using this set-up with Gopro hero 3 black and my iPad mini. I would recommend checking out HLT forums they are very help in getting things set-up. Harry is also ver responsive to set-up questions.
Slopesider can chime in as well, but I'm pretty sure the *only* BT OBD2 device that will work with an ipad/iphone that is not jailbroken is going to be the GoPoint BT1 I mentioned above, about $100..
If you have a jailbroken iDevice, most of the cheapo ELM327 dongles can be made to work, though they can be difficult to get set up properly. You will need additional Cydia Apps, RoqyBT4 and RoqyOBD. Roqy charges a few bucks to enable full functionality with the OBD2 device.
If you are not familiar with jailbreaking, or don't know what Cydia is, or have a IOS version for which their is currently no jailbreak, I'd suggest just going with the GoPoint BT device for the extra $70 or so and having a fully supported solution.
I'm using this generic BT OBD2 device with my Jailbroken iPad mini, with Harry's Lap Timer, with GoPro Hero3 wifi connection.
Using an extension cable helps put the BT dongle in a better location, .
Slopesider can chime in as well, but I'm pretty sure the *only* BT OBD2 device that will work with an ipad/iphone that is not jailbroken is going to be the GoPoint BT1 Imentioned above, about $100..
I'm using this generic BT OBD2 device with my Jailbroken iPad mini, with Harry's Lap Timer, with GoPro Hero3 wifi connection. $24 on Amazon.
Using an extension cable helps put the BT dongle in a better location, $9 on Amazon.
I'm using the GoPoint BT1 because seemed to have the least issues. There are others that will work but the BT1 is the preferred dongle.
Check out this form http://www.gps-laptimer-forum.de/viewforum.php?f=20 for more info. Harry has conducted extensive testing and will out line exactly what you need to do to get everything working.
I bought the same Wifi unit and software as the OP. In the setup of DashCommand where you select your car, they list "Porche", which doesn't give me a lot of confidence in the software. It also doesn't list any models under that heading. Not sure if that has any bearing on what data it pulls down, but it can't get my VIN. My ordinary ODBII reader pulls in the VIN without any problems.
Has anyone else encountered this and do you have a workaround?
I also bought the cable. Any suggestions on where and how to mount it?
