Yes, but as Mike said, assure it's actually the joint that needs replacing. If it's just the boots, much cheaper. Look into other items. That "grinding" during left turns could be many things. Start simple, and work out to the larger items, that may be the problem. Sorry, if you're stuck with having a shop/mechanic do it for you. You're at their will.
