993 Turbo Forum 1995-1998
front drive shaft
Old 06-27-2017, 01:33 AM
JHR55
JHR55's Avatar
Default front drive shaft
please help. need change front driveshaft. part no. 993 349 038 03.
cant find it. are they the same as the rear driveshaft
Old 06-27-2017, 01:51 PM
OverBoosted28
OverBoosted28's Avatar
Old 06-28-2017, 05:04 PM
Mike J
Mike J's Avatar
Why do you need to change them? They very rarely fail, the boot is split? If so, you can just change those out.
Old 06-29-2017, 05:21 AM
JHR55
JHR55's Avatar
there is a grinding sound when i take left corners.
mechanic most probaly shaft need changing
Old 06-29-2017, 08:27 AM
JHR55
JHR55's Avatar
Old 06-29-2017, 08:28 AM
JHR55
JHR55's Avatar
is the kit above for repair driveshaft?
Old 06-29-2017, 12:10 PM
OverBoosted28
Yes, but as Mike said, assure it's actually the joint that needs replacing. If it's just the boots, much cheaper. Look into other items. That "grinding" during left turns could be many things. Start simple, and work out to the larger items, that may be the problem. Sorry, if you're stuck with having a shop/mechanic do it for you. You're at their will.
Old 07-02-2017, 08:26 PM
pstoppani
pstoppani's Avatar
For me, its been a wheel bearing when I had grinding sounds when turning...
Old 07-03-2017, 03:54 AM
911PERVY
911PERVY's Avatar
That joint you have highlighted is no good for the front of a 993 turbo.
Quick Reply: front drive shaft
