993 Turbo Forum 1995-1998
WHY does the 4wd make the steering so numb?
Old 12-30-2015, 07:20 AM
ACEparts_com
ACEparts_com's Avatar
Default WHY does the 4wd make the steering so numb?
I've wondered why the 993 turbo steering is a little 'vague' since day one of ownership and wonder how much of it is due to the front's being powered vs geometry in general?
Every other awd / 4wd car can manage it. Even some FWD cars!
So, before I rip the front bits out, anyone?
Old 12-30-2015, 09:05 AM
Quadcammer
Quadcammer's Avatar
Received 1,371 Likes on 794 Posts
I don't feel that way at all. A set of walrod bushings and some pinned tie rods and the steering is pretty precise to me.
Old 12-30-2015, 12:13 PM
OverBoosted28
OverBoosted28's Avatar
^^^^^I also have the poly rack bushings, along with H&R sways, and I am happy with feedback, input response time. I am sure other cars are clearer, but I am not missing much feel as far as I'm concerned.
Old 12-30-2015, 01:16 PM
Basal Skull
Basal Skull's Avatar
Maybe the steering in 2wd is a little lighter? due to less wt and drive shaft having to be moving parts when steering but I didn't think the steering was 'numb' in 4wd. You can change the feel quite a bit with alignment and stiffer bits as above.
ACEparts_com
That's a good point - I need to pin / weld up my tie rods again. Might try putting some air in the tyres.
I've always felt the steering only gives feedback when pushing on but I guess with a 185mph performance envelope, not much can be expected at 30.
Old 12-31-2015, 03:13 AM
Mike J
Mike J's Avatar
Try one of the new pcars (991's etc) and then you will be happy with your 993 - took a GT4 out a while back, the steering was very numb, virtually no vibrations through the wheel or the seat. Fantastic turn in though, much better, but it was hard to tell what the turn in was doing. It was bad enough that I cancelled my order (and I had a confirmed allocation).
Cheers,
Mike
Old 12-31-2015, 06:34 AM
ACEparts_com
Ahhh, I think I should have used a different word. There's plenty of feedback but a lack of precision compared to new cars.
Everyone says how converting to 2wd makes the steering feel more 'alive' and I wondered why as other manufacturers manage it?
Old 01-01-2016, 07:37 PM
ronnie993tt
ronnie993tt's Avatar
My first Porsche test drive many years ago comprised a 997S, 993C4 Cab and a 996C2 in close succession. The 993 was my hands down favourite because of it's connection to the road in spite of it's AWD/cab disadvantage. Add the turbos and even after driving several dozen other Porsches, the 993tt remains my favourite road car.
Old 01-03-2016, 08:48 PM
997rs4.0
997rs4.0's Avatar
Originally Posted by ACEparts_com
I've wondered why the 993 turbo steering is a little 'vague' since day one of ownership and wonder how much of it is due to the front's being powered vs geometry in general? Every other awd / 4wd car can manage it. Even some FWD cars! So, before I rip the front bits out, anyone?
What kind of wheels do you run? I have heavy RUF wheels and definitely makes the steering more vague compared to something lightweight.
Old 01-08-2016, 02:26 AM
tcsracing1
tcsracing1's Avatar
i love the feedback from the awd 993 steering. you can feel the front scrabbling for traction!
Old 01-08-2016, 03:22 PM
ronnie993tt
Time for a pair of shaped skis there tcs!
Old 01-10-2016, 10:51 AM
Felix
Rennlist Lifetime Member
Felix's Avatar
Can't quite make it out but ski brakes might be an idea as well.
Old 01-10-2016, 05:18 PM
Felix
Felix's Avatar
I recall fitting walrod bushes and GT2 tie rods to my 993tt and it took a lot of vagueness away.
Old 01-14-2016, 08:41 PM
pstoppani
pstoppani's Avatar
The AWD shouldn't effect precision/vagueness; none of which I've experienced in mine. Sounds like you need a bushing overhaul...
Old 01-15-2016, 05:09 AM
TB993tt
TB993tt's Avatar
Originally Posted by pstoppani
The AWD shouldn't effect precision/vagueness; none of which I've experienced in mine. .
I don't think I agree with this statement
My experience of converting to RWD only with all correct parts (inc a new end for the gearbox) turned the steering into a thing of wonder, super precise even more so than my 997GT2 (with solid joints). 993 turbo in this set up (with RS/GT2 parts) is absolutely go kart like (don't forget the -50kg helps big time in this). In comparison refitting the the 4WD loses 60% of this sharpness and feel.
Non withstanding the above I've driven standard set up 993 turbos and the steering is pretty numb IMO, fit parts from the RS/GT2 and even in 4WD it can be made into a decently sharp tool at the front end but nothing as scalpel sharp as RWD only.
Having said all the above the old chassis tech on these cars means they become a bit dangerous with over about 650NM and RWD only, the GT2 racers had massive tyres and radical geometry to keep them straight, a standard tyred/geometry 993 turbo in RWD with big torque is quite dangerous on normal cambered road, it will attempt to throw you into a hedge when the boost comes in if on a camber - see what the guy in the GT2 video on here says, it's true.
Quick Reply: WHY does the 4wd make the steering so numb?
