revised Ultimate PPI
Ok so I found the post on the Ultimate PPI and I added some things to it. Is there anything missing?
Also what should I look for in the service history as 'normal' maintenance, besides oil changes? These are some things that I found.
1)Timing belt replacement (expensive)
2)Plugs and wires, ( around 1200.00 just parts)
3)brake pads (400.00 just parts),
4)air conditioning service,
ULTIMATE PPI:
TEST DRIVE
full throttle in 2nd (once warm), ensure 0.8bar boost (not "limp home mode") and check for clutch slippage
idle at 880 +/- 40rpm
make sure no stall on quick stop with A/C on
check for wheel rub (full left/right lock while forward/reverse)
test ABS (ABD if possible)
watch temps.
Ensure oil thermostat opens
listen for oil cooler fan speeds at stop
Check braking (no shudder/squeal/pull to either side)
Ensure smooth power steering
downshift into 1st at ~15mph to ensure easy engagement, no odd noises
upshift and downshift into 2nd at a variety of speeds, ensure no cruchiness
or notchiness
whilst rolling (5+ mph) in first depress the clutch and listen. Any whining is a bad sign
TURBOS
check for oil leakage
look inside pipes (turbo to intercooler) for oil
check weak turbo hoses on the earlier cars
Worn Turbo Bearings - If the car has been driven very hard and the previous owner didn't let the turbos cool off before shutting off the engine, damage to the Turbo bearings could occur and start to leak. Have the mechanic check the Turbos for oil leakage. If the bearings are leaking, the Turbos must be replaced. They aren't cheap.
CLUTCH
ensure no clicking or hanging up in clutch pedal motion (engine stopped and running) points to slave cylinder problems
no signs of slippage
accumulator
check for hard pedal before start
check for pentosin leaks from accumulator/slave
DRIVETRAIN
visually inspect rear diff., viscous coupler, front diff. (for leaks, damage)
check rubber CV joint boots for tearing/cracking
check Transfer case leaks or breakage
ENGINE
- compression test all six cylinders
140-155 psi. Most important thing is to have a small variance between cylinders (less than 15%).
Do the compression check with the throttle wide open.
consistency cylinder-to-cylinder is more important than the ultimate number
perform a leakdown test on all six (2 hr work) (replace the spark plugs)
write down where the leakage was. Crankcase, intake or exhaust
1 to 2% is perfect
3 to 5% normal
6 and 7 % wear setting in
8% kiss your money in your wallet goodbye
9 and 10% worn guides, possible cylinder liner problems
- check serial number should begin with 61V (1996) or "61T" (1997)
- check distributor, coil(s), plug wires for visible damage
- check engine tray (if installed) for oil deposits
- check for all fuses/relays (match w/ diagram on box cover)
- check valve covers, timing chain covers for leaks
-Hydraulic tappets
-Valve lifter failures (esp. exhaust side)
-Longevity of basic pipes (i.e. intercooler oil)
Valve wear:
-Listen intently for any excessive tappet noise, especially on the exhaust side, since that is a common problem in higher mileage cars. Slapping tappets may be indicative of more expensive valve wear.
Fan cooler
-check fan cooler. Symptom, oil temp. goes up to ten o'clock on the gauge when stuck in traffic. Anything over eight o'clock with engine off but ignition on should have the oil cooler fan running at slow speed. If it doesn't it means this resistor has failed. It's in series on the low speed circuit of the fan. There's different solutions on this board for this one but all I did was bridge this resistor causing it to run at high speed when oil temps come up to eight on the gauge
ECU/DME
(OBDII) read fault/readiness codes
-See if shop can hook up to ECU and print engine hours, and error codes
-CEL (Cash Evaporation Light)
-CEL leading to a valve job.
-CEL for blocked air injection (I think this was only for the NA 993, not the Turbo)
WARNING LIGHTS
all come on with key on, extinguish upon start
- make sure CEL not tripped (check OBDII to rule out removed bulb)
-check LCDdisplay on OBC for full functionality
Carbon Build-up Problem
Additionally, the engine light may come on because of a problem with some small holes in the air pump lines getting blocked because of a carbon buildup problem.
CLIMATE
- A/C blows cold
- heat blows hot
- all climate control functions work (buttons/switches functioning)
STEERING
- check steering rack for leaks
- check rubber boots for tearing or cracking
- inspect p/s pump for leakage
-Steering bushes @ 55k
-Other steering geometry
-Need for regular 4wd alignment
OIL LEAKS
- check under engine
- timing chain covers
- lower valve covers
- smoke on start?
- smoke once warm?
MISC
- tool kit present
- jack present
- air compressor present
- door locking (from all switches and remote)
- alarm
- number of key fobs
LIGHTS
- driving lights
- head lights
- tail lights
- 3rd brake light
- fog lights
- interior
- trunk/engine lid lights
- glove box
- all turn indicators, including hazards
BODY
- check for rust, especially near bottom corners of windshield seal and around seals
- remove headlights, check for impact damage/paint work/metal work
- any signs of impact damage
- check for even gaps either side of hood, trunk
- ensure engine bay stickers
- ensure sticker under luggage compartment (trunk) lid
- level turbo badge
- inspect for rolled fenders
- if possible paint thickness meter?
- check for repainting/overspray around plastic, in door jams, etc.
- trunk
- look for corrosion (beneath fuel tank, brake reservoir, around bolts)
- check under spare wheel for rust, ensure drains OK
- look at ABS/ABD control unit for corrosion
- inspect for paint damage beneath hydraulic components
- check for small cracks in front bumper (should exist on 11yo car)
- install tow hook should thread evenly and straight
- check taillight (condensation)
- remove rear bumper (front also if not too time consuming), check for repaint/metal repair underneath
- check seals (pour water down leading edge of doors, sunroof)
- check door for missing, clicking, loose straps/stops
INTERIOR
- check condition of vinyl/plastic/fabric
- check function of electric, heated seats
- power windows (ensure every switch works)
- test front wipers at all speeds (including delay)
- check windshield and headlight sprayers
- ensure function of rear wiper (if installed)
- defrost
- rear window, windshield, outside mirrors
- electric mirror controls work
- check AM/FM/CD/tape(?) for function
- check clock for function
- ensure sunroof opens, closes
ULTIMATE PPI:
TEST DRIVE
watch temps.
or notchiness
TURBOS
CLUTCH
accumulator
DRIVETRAIN
ENGINE
1 to 2% is perfect
3 to 5% normal
-Hydraulic tappets
Valve wear:
Fan cooler
ECU/DME
WARNING LIGHTS
CLIMATE
- A/C blows cold
- heat blows hot
STEERING
OIL LEAKS
- smoke on start?
- smoke once warm?
MISC
- tool kit present
- jack present
- alarm
LIGHTS
- driving lights
- head lights
- tail lights
- 3rd brake light
- fog lights
- interior
- glove box
BODY
- level turbo badge
- trunk
INTERIOR
- defrost
Jeezis, if you came to look at my car (if I was selling) I would be hiding under a desk in a fetal position!
That really is one hell of a list you have. I had no idea this is what people checked on, what is now a 15 or 16 year old car. make sure you check the vanity mirror sliders work.
Have fun
Have fun
I have no idea how you could do a leakdown test in 2 hours. I had one done in 5 hours (and I was standing next to the car; ok distracted by an italian aperitivo in the workshop with wine ans salami) but we could only check 5 cylinders.
For the last cylinder it would have been necessary to remove the turbo and part of the exhaust but since all 5 other cylinders were perfect we did not check the last one.
I would say in real life the ppi proposed is almost a joke. It will cost you at least 1k Usd per car checked.
andreas.
andreas.
In an NA engine 2 hrs seems about right from what mechanics have said/charged, because they can get to the lower plugs on the twin plug engine easily. Not so, it seems, on the Turbos.
Scott,
I would charge $650 for a 993TT. But I also would talk to a customer about this being a car that was worth buying in all other areas before I performed the compression and/or leakdown. And if it was I would quote 6 spark plugs to replace at this time.
I also think it is a good idea to always do a compression test during a major service when you are replacing plugs in these cars thru 1998.
