993 Forum 1995-1998
Control Bushing Question??
Old 09-05-2015, 03:38 PM
95_993
95_993's Avatar
Default Control Bushing Question??
I am replacing the front control arm bushings today.
Do I need to separate the ball joint from the carrier or do I just unbolt the ball joint from the a-arm??
I dont want to risk tearing the boot on the ball joint if i dont have to.
Old 09-05-2015, 04:13 PM
Vandit
Vandit's Avatar
When I did this job in my 964 I left the ball joint attached to the wheel carrier and removed the ball joint assembly from the arm. So yea, you can do it that way.
Old 09-05-2015, 04:59 PM
OverBoosted28
OverBoosted28's Avatar
Make a reference on the ball joint eccentric, then just unbolt it.
Old 09-05-2015, 05:46 PM
95_993
95_993's Avatar
Thanks guys!
Old 09-05-2015, 10:37 PM
AOW162435
Seared
AOW162435's Avatar
^ This. Either two center punch marks or precise paint marker 'ticks'.
Andreas
Old 09-05-2015, 11:08 PM
95_993
95_993's Avatar
Worked perfectly. Control arms are out. Two buhings out and I will be wrestling the rest of bushings out in the morning. It's been a busy weekend. I managed to get Bilstein HD's with ROW M033 & Tarret toe links installed. Once I finish up the bushings, it's off to be corner balanced and aligned on Wednesday
Old 04-04-2016, 11:00 PM
dlinzy993
dlinzy993's Avatar
I'll check back on you to see how you get the rotor back in place, it was a true ***** on mine.
I finally placed the jack under the tie rod and lifted it and wrestled it until i got it back.
Now it's back to the alignment shop.
First one i too off the sway bar link and the ball joint, second one I marked the concentric ? SP? and fought it to the death.
Good Luck,
Denny
Quick Reply: Control Bushing Question??
