Security System
Security System
I noticed that my car sometimes locks the doors without anyone pressing the button. I have been working on the car and was locked out, good thing I was in the garage so I could use my other keys and get back in. Now I have to very careful not to forget to keep the keys on me and never leave them in the car with the door closed.
Anyone else have this issue or heard of it happening. Would like to correct this but not sure where to start.
Sometimes the door pins stick the ones in the door pillars for the interior lights, if they stay stuck in when you open the door to get out ( even if the doors locked it can still be opened from the inside) the centre locking system doesn't know the door has been opened and closed, so the door re locks and locks you out the car
Not sure I understand. I pressed the button and unlocked the doors, then opened a door to get in the car. Once in the car I then forgot something and exit the car to get it. I close the door and leave the keys in there, while out of the car the system locks the doors without any direction from me. My keys are now locked in the car. It seems that it thinks someone pressed the button when no one did.
I added a delay timer relay to my car that locks the door a few seconds after the ignition is turned on. I once locked myself out of the car after starting it while not seated in the car. I I now know better than to do this. Dooooop!
Andy
Andy
Oblivious you did open the door, got in closed the door then reopened it to get out, but as the car did not get a signal from the door pin switch, it thinks the door remained closed throughout and starts it's re locking count down timer and locked you out the car.
Most modern cars do the same, try it if you have access to a modern car, unlock the car with the remote but don't open the door, after a minute or so the car will re lock on its own
So probably worth checking your door pin switch before resorting to a priest ;-)
The door lock actuators in the RH and LH doors have a switch in them that signal to the door lock controller if the actuator is in the locked or unlocked position. You could have an actuator that failed so the actuator rod is always in the locked position and the switch is telling the controller that the system needs to rearm. Just a thought.
