suddenly mis-fire
suddenly mis-fire
early morning drive the car within 5 min, suddenly mis-fire when stop in traffic light. but after 2 min, it can fire again. so i keep driving it, after 10 min in normal drive, it happen again. The DME just use few month.
what should i look at ?
furthermore the fuel pump and filter just use it less than 5000km.
Either that or the fuel filter clogging when the engine is running but when the engine stalls and pressure inside the filter is released, the trash in the filter "falls away" from the element, allowing it to start again. Then the cycle repeats itself.
But I would change the DME relay first.
thanks for all input.
there are no CEL issue.
this morning make a test drive for 30 min, there are no more mis-fire again ( touch wood).
really don't know what make the mis-fire on yesterday drive.😦😦
one more question, will the loose fan belt cause the demage of DME. i did unplug the fan belt sensor and it still can fire the car, it just the belt light on the clock.😟
