Is this exhaust valve guide wear
#32
This one [#3] was my worst one. All exhaust valves were out of spec, and are getting replaced. <br/><br/>No major surprises, cam gears getting backdated, and clutch/flywheel was done 3 years ago. Replacing lifters. New sound pad and new clutch slave and master.<br/><br/>
#33
Kika - everything on your list to-do list is on mine except the clutch slave & master. How did you decide to include that? Just asking to see if I want to add it to my "while I'm in there" list.
#34
Keith,
I have read and heard some very good things on the MPL clutch slave.
Just thought I'd pass it along for your consideration...Yeah, its more money.
https://rennlist.com/forums/993-foru...-cylinder.html
#35
Keith,
A recommended upgrade on heavier clutches. Stock or RS NA clutches not needed. Recommended for Turbo clutches if you remove the power assist (for better feel). There are a few of us in Vancouver who have gone manual on our Turbos for just that reason, and are using MPL's to lighten the load (and lower the wear at the pedal cluster).
Cheers,
Mike
#36
