Shorted Oxygen Sensor in a '95 993
Hey folks,
My CEL has been on for sometime and I finally got around to decoding it using the ignition-gas pedal trick. I've got a '95 993 with OBD 1 so it can be a little harder to tease out the codes. Anyhow, it does not surprise me in the least that my O2 sensor is shot. The car's gas mileage hasn't been as good as I anticipated so I suspect this sensor might be the culprit.
I have done some poking around on the forum using the search feature and it seems like most O2 sensor threads are for non-95 993s. '95 993 only has 1 O2 sensor, rather than 4. (Yet another reason by '95 is the best MY) It looks like the BOSCH brand part through sunset will cost about $120.
I'm curious how easy of DIY swapping out this sensor would be? My gut is telling me it should be super easy to do, but I'm wondering if I am missing something. Are there any special tools that I'll need? Can I accomplish this repair by backing the car onto a ramp and not having to remove the wheels and bust-out the jack stands?
It will be plainly obvious where the sensor installs in the exhaust, but I'm not 100% certain where the electrical contact connects to. I suspect that too will be obvious once I'm under the car, but I'm curious if anyone can warn me as to how much of a PITA it will be to reach the plug end of the sensor cable.
Thanks in advance! Photos are welcome too!
IIRC, when I swapped mine out it was relatively straight forward. I think I used a large adjustable wrench. The wiring goes up through a small metal clasp-like holding thing (to keep the wire away from hot things like exhaust) which is held in by a 10mm allen head bolt. Then the wire goes thru a rubber grommet (oval shaped) into the engine compartment (carefully pry up with screwdriver) and then off to the right. You will see a black plastic cover on the right side of engine compartment. That is where it get connected/disconnected.
Edit: I think the allen bolt holder is 6mm.
The grommet is located directly under the A/C Compressor. Here is a pic:
Last edited by Vorsicht; 10-29-2014 at 09:26 PM. Reason: change condensor to compressor. Doh!
Very easy diy. Unscrew the sensor, follow the wire up through the grommet and unplug. Takes 10 min.
Scott- I've never done this DIY, but isn't it easier to disconnect first then unscrew the sensor? I've done O2 sensors on other cars before and the wire gets all twisted.
some pics from my recent O2 R&R
Hi, since you asked for some pics before starting I thought I would post these up.
This is on a 97 but the procedure would be the same. You can cut the wires on
the old sensor if you want before removing to eliminate snarls. You only need to
raise the car enough to swing the wrenches.
Good luck!
-bruce
Snap-on Oxygen Sensor Socket Drive, 22mm Hex, 3/8 Drive, Item SWR2, $37.80
Other side.
How it fits the O2 Sensor.
Removing the old O2 Sensor with a breaker bar.
O2 sensor comes with graphite paste on the threads. Try not to disturb it while handling the sensor.
Torque the O2 Sensor to 50-60Nm. I used 50 and it was tight enough.
Protect the plug end to keep dirt and gunk out of the connector while installing.
Good luck!
-bruce
Other side.
http://www.warehouse33auto.com/99360...126-01-w00.htm
It was a little more expensive but perfect fit. The first one I ordered from Amazon (not the one mentioned above) was too short and had to send it back.
