Oil leak - what is this part?
Hi all,
I have a small oil leak that appears to start at (I think) a sensor and drips down to the centre of the engine. The picture is taken from below on the driver's side looking toward the back of the car and behind the differential. Sorry for the crappy pic....hope you can make it out.
What is this part?
Thanks,
Ron
What is this part?
Thanks,
Ron
Hmm. That looks like the flywheel sensor. Not a typical leak point unless it is the rear main seal (RMS). Not likely if the rubber gasket is around the sensor. Probably coming from somewhere above. It is nearly impossible to locate the source of the leak without cleaning first.
Get under there and clean the whole area as far as you can reach. Then drive the car 10 minutes and have another look.
Ok, will do.
I did use an inspection mirror to look for any traces of oil above that sensor and didn't see anything but I'll clean it up as best I can and take another look.
Also look in front of area and see if there's seapage that gets drawn back during forward movement. The film on the front of the sensor could've accumulated from a leak forward of it.
So, I cleaned up the area as best I could and took it out for another run but it still looks like the oil is coming from the flywheel sensor. Upon closer inspection of the sensor, it looks like I'm missing a grommet as I can see the teeth of the flywheel. I've attached an extract from PET and believe part #26 is what I need.
However, that doesn't explain why oil is coming from this area unless I have an RMS leak or ???
This is a bit curious because usually there would be oil at the bottom of the housing also. Can you check that?
If you are sure the leak is coming from within the housing then it is most likely the RMS. When was the last time it was changed? Mileage on car? If it is not leaking too much you can just wait until you need a clutch job and do it then (or for some other engine out maintenance). This is a bit curious because usually there would be oil at the bottom of the housing also. Can you check that?
I'll order the part and keep an eye on the leak. Thanks for the feedback.
Well, I replaced the rubber grommet for the flywheel sensor but when I checked it a few days later, it was gone again! Am I missing something or does that part just sit in there with no way of retaining it in position?
In terms of the oil leak, is there anything above the sensor where oil can leak from?
There's 85000 miles on the car right now but according to the paperwork I have, the rms was replaced at around 75000 miles when the transmission and front differential were out for a rebuild. There is oil at the bottom of the housing but I think it's just dripping from the sensor opening. Clutch was replaced at around 65000 miles with an RS clutch and LWF at the same time.
I'm surprised the rubber piece up and went. It is a friction fit and I remember I had to use a screw driver to get it in tight.
Back to the RMS. How much oil is coming out? I would just watch it and as said before you can get to it whenever the engine needs to be dropped (like a clutch job). On the other hand if oil is pooling on your floor you will have to address it.
